ac problems
ac problems
Started hearing a gurgling sound form the ac. It dosn't get cold just barely cool.
I can turn the ac off and on and hear the compressor kicking on. Checked the pressure of the freeon a month or so ago seemed to be fine. 1997 accord ex 4cly
Re: ac problems (Steve LeB)
Sounds like you might need a re-charge, & possibly have a leak. Take it to a shop so they can put dye in the system & refill it. Should only cost you about $45
ok I'm having a AC problem as well..... the compressor is not kicking on when you hit the switch, but the rear defroster is working. Can this be the compressor or the relay... in which I'm having a hard time finding.....
Re: (IceNiceNess)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IceNiceNess »</TD></TR><TR><TD CLASS="quote">ok I'm having a AC problem as well..... the compressor is not kicking on when you hit the switch, but the rear defroster is working. Can this be the compressor or the relay... in which I'm having a hard time finding.....</TD></TR></TABLE>
Check all of your fuses... I had the same problem a few weeks back, You might need a re-charge. Just go have it checked out, its VERY cheap, sometimes free.
Civic Racer X 7
08-08-2007 05:15 PM
jlamaster
10-01-2004 07:12 PM
