bosch unversial o2 sensor help??? wiring help ASAP
Old 08-05-2006, 09:00 AM
JonCoop's Avatar
Default bosch unversial o2 sensor help??? wiring help ASAP
i just bought a bosch unerversal 02 sensor i have to connect the wiring harness for the old one to the new bosch one.. on the plug it has 2 black a white and a green.. on the o2 sensor it has 2 white a black and a gray... the instructions are not staright forward and i cant figure them out... please help
i bought the oem one but the wireing plug on the car is female and the oem sensor had a female as well
Old 08-05-2006, 09:02 AM
JonCoop's Avatar
Default Re: bosch unversial o2 sensor help??? wiring help ASAP (JonCoop)
the car is a 94 honda accord lx
thanks
Old 08-05-2006, 09:22 AM
JonCoop's Avatar
here is the instructions that came with it: http://www.boschautoparts.com/...l.pdf
Old 08-05-2006, 10:22 AM
teamlegacy's Avatar
Return that Bosch piece of **** back to Autozone and ride down to the Honda stealership and get the proper one. Or if you can't do that, go to an import parts store and get a Denso or NTK/NGK whatever it is one. DO NOT USE BOSCH.
Old 08-05-2006, 10:40 AM
iam7head's Avatar
Default Re: bosch unversial o2 sensor help??? wiring help ASAP (teamlegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">Return that Bosch piece of **** back to Autozone and ride down to the Honda stealership and get the proper one. Or if you can't do that, go to an import parts store and get a Denso or NTK/NGK whatever it is one. DO NOT USE BOSCH.</TD></TR></TABLE>
that's pretty much sums up the whole bosch deal with honda electronic.
on obd1 and non ulev/sulev car you might get away with it, but later model accord will still throw a heater circuit code
gATOr65
01-16-2006 03:39 PM
patastinky
07-19-2005 01:24 PM
brawl
09-18-2003 03:58 AM
Quick Reply: bosch unversial o2 sensor help??? wiring help ASAP
