BARO sensor
Old 11-15-2007, 12:57 AM
honda671's Avatar
Default BARO sensor
I NEED HELP LOCATING THE BARO SENSOR( ATMOSPHERIC PRESSURE ) I HAD CODED MY ACCORD AND WAS CODE 13 -BARO SENSOR DEFECTIVE CIRCUIT OR UNPLUGGED/ DEFECTIVE SENSOR---
WHAT CAN I DO--THANKS
Old 11-15-2007, 03:16 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: BARO sensor (honda671)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda671 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT CAN I DO--THANKS</TD></TR></TABLE>
Stop typing in caps to start with
I dont know much about this but if I'm not mistaken the barometric pressure sensor is built into the ecu. I would first try resetting the ecu by pulling the back-up fuse from the under hood fuse box, leave it pulled for about 30 second and that should reset your ecu. Put the fuse back in and turn the ignition on, do you still have a CEL that reads 13? If so, I would try finding another ecu from someone that you can try, if it works and you dont have a CEL then you know the ecu was the problem and you need to replace it.
Hopefully someone with more knowledge on this will chime in
Old 11-15-2007, 05:21 AM
GhostAccord's Avatar
Default Re: BARO sensor (TouringAccord)
You got'er TA. Not much more you can do but test your ECU.
If your Baro sensor is messed up your going to have to replace your ECU. It is not a part that can be easily replaced. It is soldered directly to the main-board of the ECU.
Old 11-16-2007, 12:21 AM
honda671's Avatar
Default Re: BARO sensor (GhostAccord)
thanks guys!!!and yes i did try resetting my ecu but still CEL is on so i guess a new ecu will do,can anyone loan me $2,500 for my new ecu? christmas is around the corner.better yet since you all live near santa why not stop by and drop a few lines about my ecu
Old 11-16-2007, 04:11 AM
H-T Order of Merit
that made no sense to me...
you are looking for a F22B2 5spd ecu right? I'm sure you can find one of those on here somewhere, most likely from someone that did a motor swap and no longer need the ecu. Look around the Marketplace and also check out the FS/WTB sticky at the top of the Accord forum.
Old 11-16-2007, 04:22 AM
twkdCD595's Avatar
I will asure you, you can find an ecu for WAAAAAAAYYYYY less than that in the yards or online.
Hell if you dont, pm me and I will find one for you... your not paying that kind of money.
Old 11-16-2007, 04:27 AM
Default Re: BARO sensor (twkdCD595)
P0A-A01 form a dealer is only $620. Probably get on on ebay for $60+ shipping
Old 11-16-2007, 05:40 PM
jravensc's Avatar
I'm just throwing this out there, because I'm really not sure whether his car has one or not, but isn't it possible for the BARO sensor to be part of a MAP sensor? I'm sure with the expertise roaming this forum someone would have probably said that if it was the situation. I just thought I would ask.
(I am aware that a car with IAC normally doesn't have a MAP. I just don't know what his kind of accord came with.)
Old 11-16-2007, 06:19 PM
Default Re: BARO sensor (jravensc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jravensc &raquo;</TD></TR><TR><TD CLASS="quote">(I am aware that a car with IAC normally doesn't have a MAP. I just don't know what his kind of accord came with.) </TD></TR></TABLE>
What do you mean by IAC?
If you are referring to the Idle Air Control (IAC) valve then yes the 95 Accord LX has an IAC. They also use a map sensor that is attached to the top of the throttle body and the baro is soldered to the ECU.
Old 11-17-2007, 02:11 AM
honda671's Avatar
hey guys! thanks for the help once more and i will check out the nearest junk yard for an ecu.i did check with the honda dealer here and that was what i was quoted but i will not pay with that kinda price,but yea i will look around check the yards and friends with friends...happy thanksgiving
Old 11-17-2007, 01:12 PM
jravensc's Avatar
My bad. I said IAC, but I meant MAF.
Old 11-17-2007, 04:41 PM
IC
wakaranai
19
11-06-2008 09:52 PM
austinkli
06-21-2008 11:11 AM
i_drive_a_honda
12-20-2007 02:34 AM
go-fast
05-17-2007 03:09 PM
h22aLSD
11-18-2003 09:54 PM
Quick Reply: BARO sensor
