squeaking noise while braking
Old 08-01-2006, 05:38 PM
paxorion's Avatar
Default squeaking noise while braking
i just noticed today, that my 04 accord lx sedan (51k miles w/ the original brakes when i bought my car new) has a very faint squeaking sound coming from the front right whenever i am braking and coming to a complete stop when my speed drops under ~10-15mph. i don't notice any difference in the ability to brake, or a change in the way my car stops.
anyone have any clues as to what might be happening?
Old 08-01-2006, 06:03 PM
YeuEmMaiMai's Avatar
Default Re: squeaking noise while braking (paxorion)
inspect your brakes and make sure that they are not worn down. If they are fine, but some anti squeak on the shims
Old 08-01-2006, 06:48 PM
hondadude's Avatar
The newer honda brake pads are a really hard material[compared to early 90's] and rotor glazing is a problem, look at the rotors and if you can see yourself in the rotor it's time to have them resurfaced, as a test you can scuff them up with some 60 grit sand paper to see if the noise goes away for a day or two. Also when the pads wear down pretty far the pad material can't dissapate the heat and the pad will get cracked and cooked. I hate that high pitched sound, puts my teeth on edge and makes me want to wear earplugs. There is a service bulletin about this problem.
Old 08-04-2006, 06:12 AM
paxorion's Avatar
what material are the brakes that 04 accords are equipped with? i was told when i called a merchant's tire and auto center that they used ceramic brakes?
Old 08-04-2006, 09:59 AM
civicboisi's Avatar
It should be a Ceramic Pad.
There are Organics and Semi-Metallic that works just as good, but you get a harder pad as someone stated above and more brake dust with these two.
Old 08-04-2006, 06:30 PM
standbackimapro's Avatar
just, get some new brake pads
Put the grease on the shims
if thats not it, Try replacing the Slider boots
canooten
11
09-12-2014 09:39 AM
dbbyleo
08-30-2008 01:06 PM
Landshark68
04-20-2007 10:01 AM
M4
06-09-2006 10:13 AM
Acuracy
09-02-2002 03:57 AM
Quick Reply: squeaking noise while braking
