Squeak/Squeal when backing up. - Honda-Tech
Old 02-19-2007, 03:34 PM   #1
SilentSnow's Avatar
Default Squeak/Squeal when backing up.
I have just ran into a problem that may sound simple but I can't find a cure. After I start my car and start backing up I get this loud squeal/squeak from the rear of the car. I thought it could be the emergency brake but that doesn't seem to be a problem. I had my brakes replaced a few weeks ago so I don't think it's my brakes going bad already. It's not a mild squeak, it almost sounds like I'm running over a cow. Maybe I'm missing something but can someone give me some advice?
SilentSnow is offline   Reply With Quote
Old 02-19-2007, 10:14 PM   #2
Haccordclub's Avatar
Default Re: Squeak/Squeal when backing up. (SilentSnow)
Is it the whine nearly if not all Honda's make in reverse when backing up? Try to drive another honda, back it up, and see if it's the same noise. If not, Im not sure due to you just releasing the brakes. Good luck.
Haccordclub is offline   Reply With Quote
Old 02-20-2007, 03:25 PM   #3
SilentSnow's Avatar
Default Re: Squeak/Squeal when backing up. (Haccordclub)
I've had the car for over a year and it just started the problems. I'm not touching the brakes when it makes the noise, I'm just backing up. It's a sound I've never heard before, especially from a Honda.
Old 02-20-2007, 03:30 PM   #4
naoandlata's Avatar
What year is your accord? I'm having the same problem on my 00. I can also hear it when the car is cold and it makes the same sound when I'm braking to a stop going forward. My two mechanic friends say its the rear brakes, so I'm going to go with that first. If not then it could be the rear wheel bearings.
naoandlata is offline   Reply With Quote
Old 02-20-2007, 04:24 PM   #5
H22CD7's Avatar
Could be your rear trailing arm bushings too.
H22CD7 is offline   Reply With Quote
Old 02-23-2007, 08:47 AM   #6
SilentSnow's Avatar
Default Re: (H22CD7)
I have a 99. It's starting to get more persistent now. It will make the noise when I first back up without touching the brakes and then it will do it if I touch the brakes backing up as well, however not all the time.
Old 02-23-2007, 08:51 AM   #7
standbackimapro's Avatar
I had A Plymouth Laser A while ago, and when i went in reverse, it would also make a loud screeching sound, i changed the rear pads and everything
and it went away
standbackimapro is offline   Reply With Quote
squeak coming from car, Help please! Prudz_lude Acura Integra 5 04-06-2016 09:20 PM
High Pitched Brake Squealing When Not Braking oliebollen Suspension & Brakes 2 09-07-2015 10:00 AM
Weird Squeaking Noise Coming From Suspension......???? Riga89 Honda Accord (1990 - 2002) 5 10-11-2007 12:48 PM
engine squeak while in drive cubism Tech / Misc 0 09-23-2004 03:03 PM
Help with squeaking brakes!! bhcvc Acura Integra Type-R 7 01-12-2002 04:49 PM
Tags
accord, acura, backing, brakes, car, honda, reverse, sqeak, squeak, squeaking, squeaks, squealing, squeals, squeeks, up
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
