sparkplug gap - Honda-Tech
sparkplug gap
Old 09-22-2004, 11:12 AM   #1
mugenbb6's Avatar
Default sparkplug gap
What's the oem gap size for the 96 lx?
mugenbb6 is offline   Reply With Quote
Old 09-22-2004, 12:49 PM   #2
91exaccord's Avatar
Default Re: sparkplug gap (mugenbb6)
It should be in the manual or ask the guys at the part store, its on the computer when they look up the plugs.
91exaccord is offline   Reply With Quote
Old 09-22-2004, 01:14 PM   #3
Heat's Avatar
Default Re: sparkplug gap (91exaccord)
Quote:
Ditto.
In my manual (for my '99 LX), it says 0.04 inches, the guy at the parts store says 0.044 inches. I use the 0.044 inches.
Heat is offline   Reply With Quote
Old 09-22-2004, 05:23 PM   #4
yep
WyteNyteGSR is offline   Reply With Quote
Old 09-22-2004, 06:31 PM   #5
ChicoAccord2001's Avatar
Default Re: sparkplug gap (WyteNyteGSR)
Spark plugs are usually pre-gapped anyways, unless you buy them for the wrong application.
ChicoAccord2001 is offline   Reply With Quote
Old 09-23-2004, 10:15 AM   #6
mugenbb6's Avatar
Cool thanks. That's what they come pregapped, and I want to make sure.
Old 09-23-2004, 10:56 AM   #7
Turbowa's Avatar
Default Re: (mugenbb6)
You should always re-check the gap even if it sense pre-gapped. If the box was ever dropped or they were having a bad day at the factory they will be off. Even OEM ones from the dealer should be checked. And 0.044 is the correct gap.
Turbowa is offline   Reply With Quote
Spark plug gap spikey0123 Tech / Misc 8 11-30-2011 06:26 PM
spark plug gap size? ZenDynasty Honda Accord (1990 - 2002) 2 07-08-2005 12:07 PM
crx si spark plug gap? jcivic Honda CRX / EF Civic (1988 - 1991) 2 06-06-2003 07:09 PM
Denso Iridium Spark Plugs - Do I need to gap these? CloudDragon Honda Prelude 4 10-02-2002 06:30 PM
Spark plug gapping??? DelsolVtec18 Acura Integra Type-R 6 10-03-2001 06:49 PM
Tags
004, 0044, 22, 91, accord, f22, f22a, f22b, gap, gapping, honda, plug, rsx, spark, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
