someone help!! vtech vs non vtech
i was wondering if you could help me. i have 2 like accords i f23a5 one is the f23a1. im swapping the non vtech motor into the car that had the vtech wire harness and ecu? , i was wondering if there was a possibilty that i could use the ecu and wiring harness from the vtech to plug into the non-vtech motor? please respond im trying to put the motor in tomorrow.
Re: someone help!! vtech vs non vtech
no "H" in vtec but yes the harness will work on the non vtec motor if you use the vtec ecu you have a CEL for vtec solenoid and oil pressure switch
if you have the ecu for the non vtec engine just use that
hope this helps
hope this helps
