smells like gas
Old 03-26-2015, 11:23 AM
d3tached's Avatar
Default smells like gas
1991 Honda accord 2.2 se smells like gas while driving at speed and smell gets stronger based on throttle. Confirmed when I took my newly purchased accord off Craig's list On the highway for the first time. what is it? Injectors or more likely the lines near the canister?
Old 03-28-2015, 06:46 AM
scubacamper's Avatar
Default Re: smells like gas
Check all your fuel line connections - look for loose banjo bolts, loose fittings at the filter, anywhere fuel might be leaking out.
Start up your car and watch it idle - do you see any fuel coming out? What about when you open the throttle?
It's obviously leaking from somewhere near your cabin-air-intake and I suspect it's near the fuel filter, which is on the firewall, passenger side.
I recently replaced the filter in my '93 and thought I had it tight but it was still leaking a bit. I then took a wrench and put it on the filter itself while I tightened the bolt (as opposed to just trying to tighten the bolt while it twisted within the clamp)- that was it - it just wasn't tight enough...no more fuel leakage.
Old 03-28-2015, 12:58 PM
tamboo's Avatar
my gas smell was bad plug wires causing partial ignition.
why cant someone make wiires that dont wear out?:hmmm:
Old 03-28-2015, 04:26 PM
holmesnmanny's Avatar
Yeah, this could easily be a bad coil that doesn't fire every time or possibly a bad ignitor if the tach tends to bounce around.
cholder919
09-11-2011 05:03 PM
sleepercivic88
08-23-2008 12:14 PM
redDAinteg
02-01-2008 06:53 PM
Uncle Ben's
04-19-2006 03:56 PM
mrredrocker
16
10-06-2005 10:45 PM
Quick Reply: smells like gas
