Small oil leak on 95 Accord
Old 04-04-2008, 07:43 AM
mani_0130's Avatar
Default Small oil leak on 95 Accord
I have a 1995 Accord 2dr EX, with a manual trans. I was under the car the other day doing an oil change and i noticed it has a small oil leak. Seems to be leaking right by the oil filter, well at least thats what is seems like. Oil is running from somewhere on the upper part of the oil filter. It cannot be da oil filter it is brand new. When i drive the car fow awhile the oil ends up on top of the exhaust right by were the manifold ends well at the very bottom of the oil filter. Any ideas of what gasket i need to replace i will really appreciate so i can go straight to that point. Thanks in Advance...
Old 04-04-2008, 08:29 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: Small oil leak on 95 Accord (mani_0130)
could be the oil pressure sending unit. It's located above the oil filter, actually just above the coolant pipe that runs along the back of the engine.
May just need to remove it, put some Hondabond on the threads and put it back in.
Old 04-04-2008, 08:38 AM
casper.hughes's Avatar
sounds like a valve cover gasket be sure to change the plug seals to it will cost around 25 bucks
Old 04-04-2008, 11:14 AM
bseriescrxsi's Avatar
when you changed the oil did you make sure the oil filter only had one seal on it?....sometimes when taking the oil filters off the seal doesnt come with it and stays on there....if they are both there that will cause an oil leak
Old 04-05-2008, 07:43 PM
mani_0130's Avatar
Default Re: Small oil leak on 95 Accord (casper.hughes)
What about a type of screw that is on top of the Oil filter neck. I was told it mayt be leakin from their as well. But i beleive the oil sending unit would be a better place to look since it is a more common oil leak in these types of cars....
Old 04-05-2008, 08:58 PM
ControlledVortex's Avatar
Use an inspection mirror or improvise with any small mirror you have and take a peek up there. I have the same leak and it is not my oil pressure sending unit. The area around it was bone dry. That plug however had a puddle on it with no oil on the block except below that point. Because of the coolant pipe above it, I was not able to get an allen wrench squarely in the plug to tighten it properly. I was able to wedge one in cockeyed and tighten it a bit. I think it takes a 7 or 8mm. You could probably cut a short piece off of an allen wrench, then use that with a small wrench to tighten it down. That's my next move. Good luck!
Old 04-07-2008, 04:22 AM
H-T Order of Merit
Default Re: Small oil leak on 95 Accord (ControlledVortex)
for that plug, I probably wouldn't waste my time trying to tighten it. I would drain the coolant, remove the thermostat housing, unbolt that coolant pipe from the block to get more room to work, remove the plug, clean everything up, put hondabond on the threads of the plug and reinstall it, then put everything back together.
Old 04-07-2008, 04:55 AM
Default Re: Small oil leak on 95 Accord (TouringAccord)
TA's way is definitely the correct way to do the job and would no doubt fix your problem if in fact that plug is leaking
Old 04-07-2008, 01:50 PM
mani_0130's Avatar
yup i will give TA's way a try sometime this week i will post updates. Thanks
Old 04-07-2008, 05:48 PM
H-T Order of Merit
just be sure to verify where the oil is coming from first. If the oil is coming from somewhere higher than that plug, look at the sending unit, if it still appears to be coming from higher then obviously keep following it until you feel you've reached the source.
Always make sure before you start throwing money/parts/time at something
Old 04-07-2008, 06:50 PM
mani_0130's Avatar
Ye well i believe it is coming from the sending unit, because the block has oil from their and under, and the block is clean on top of the sending unit. Should i get just hondabond or hondabond HT, to fix the oil sending unit.
Modified by mani_0130 at 10:45 AM 4/8/2008
Old 04-08-2008, 04:16 AM
H-T Order of Merit
the sending unit is in the block, not the head.
I say Hondabond but I think it's labeled Hondabond HT
Old 04-08-2008, 09:47 AM
mani_0130's Avatar
Ohh yea lol i dont know what i was thinking when i put head. But ye they have normal hondabond and hondabond HT for high temp. Guy at honda dealer told me im better off with HT so i got that today. Know i just need to find some time to go under car and fix my problem. I will post update.
Old 04-09-2008, 07:16 PM
mani_0130's Avatar
Today i finally had time to do the job. Took out oil sending unit cleaned it really good as well as the block. Put Hondabond on treads put everything back. Turned car on checked for oil leaking and seems like no more leaking is present ... Now im going to drive around and check back to see if their is any oil. But hondabond is great, it should be fixed for good.
Old 04-10-2008, 01:08 AM
roaddoghere187's Avatar
lol u said its a small leak y worry lol j/k wat honda dont have oil problems haha
Old 04-10-2008, 04:21 AM
H-T Order of Merit
glad you got it fixed and it doesn't appear to be leaking anymore.
I believe I have Hondabond HT as well.
H-T Order of Merit
Default Re: Small oil leak on 95 Accord (roaddoghere187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roaddoghere187 &raquo;</TD></TR><TR><TD CLASS="quote">lol u said its a small leak y worry lol j/k wat honda dont have oil problems haha </TD></TR></TABLE>
uh... mine haven't/don't
Old 04-10-2008, 09:00 AM
mani_0130's Avatar
lol Ohh ye i forgot to mention that small oil leak was what i thought at first. When i peeked under the car i saw that the oil was running along the water pipe below it running all the way down by the right axle which cause me not to see the oil drip their. Their was only a small amount of oil going down towards the oil filter which is what i saw. So yea it was a pretty major leak lol. Thanks for all your help...
Old 02-28-2009, 09:01 PM
Bad_dude's Avatar
What tool did you use to take the unit off? If a socket, then what size?
Thanks.
Old 03-01-2009, 05:57 AM
Bad_dude's Avatar
What tool did you use to get the unit off? What did you have to remove to get to it? Also did you have to drain all of the oil or oil before taking it out? Was there a lot of oil coming out of it?
Thanks.
Old 03-01-2009, 08:36 AM
CBL9's Avatar
I thought I had an issue similiar to this on my 1993 Accord, yet have replacing the sending unit it turned out not to fix the problem. I had oil leaking from the O ring gasket between the oilcooler and the block. That was a PITA to replace as it was like 10 Degrees in the garage with a heater on. I had gloves on my hands, and latex gloves over them, and i was covered in coolant and oil. (I actually swapped out the entire oil cooler, and replaced with a new gasket.)
chiaxi2002
04-09-2010 08:56 PM
LOL@hondas
01-12-2009 12:18 PM
TuningHonda
02-26-2008 12:56 PM
Acco12dv6
10-02-2006 10:14 AM
96coupe
12-18-2005 01:14 PM
Quick Reply: Small oil leak on 95 Accord
