SIZING FREEZE PLUG HELP!!! - Honda-Tech
Old 06-16-2005, 10:34 AM   #1
CheeseKT's Avatar
Default SIZING FREEZE PLUG HELP!!!
I need to know if anyone is aware of the size freeze plug I need for a 92 sohc Accord. I am hoping that it just popped out and the block isnt cracked but I dont know what size to get...
CheeseKT is offline   Reply With Quote
Old 06-16-2005, 10:41 AM   #2
Turbowa's Avatar
Default Re: SIZING FREEZE PLUG HELP!!! (CheeseKT)
It shouldn't have just poped out. They screw into the block on the back side by the oil filter. I believe the head is a 19mm. The thread is pretty big, but its also fine, like a 1.00 pitch. Why are you needing one in the first place?
Turbowa is offline   Reply With Quote
Old 06-16-2005, 10:42 PM   #3
CheeseKT's Avatar
Default Re: SIZING FREEZE PLUG HELP!!! (Turbowa)
Ok heres my problem
The cap/plug that seems to be on there isnt. And there is coolant leaking from there.... all I know is that its a problem
Old 06-18-2005, 04:18 PM   #4
CheeseKT's Avatar
Still need help figuring this out...
34.3 - 35mm rear block freeze plug Charlie Moua Want to Buy 1 01-29-2011 07:52 PM
needing OEM freeze plug laziebun Acura Integra 1 02-04-2009 01:47 PM
freeze plug help integra type Gendy Honda Civic / Del Sol (1992 - 2000) 17 12-27-2007 05:21 PM
NEED HELP RE: B18b freeze plug b16clutch Tech / Misc 1 12-15-2005 11:24 AM
freeze plugs for catch can on b18c1 JBBNJ609 Tech / Misc 2 05-08-2005 04:40 PM
Tags
1990, 1992, 2005, 92, accord, f22, f22b, freeze, honda, leak, locations, plug, plugs, sale, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
