Should I add Lucas Transmission Fix to my 92 Honda Accord? - Honda-Tech
Old 04-02-2009, 10:11 AM   #1
Default Should I add Lucas Transmission Fix to my 92 Honda Accord?
I had an earlier post you may have read, but my last question is about what I add to the transmission.
I am going to flush the system, and add new Honda Genuine ATF-Z1. I was recommended to use Lucas Transmission Fix because I had the wrong transmission fluid (Valvoline Ford) for over 3000 miles.
When do I add it to the transmission? After or before I add the new fluid? Maybe about the same time - like between quarts?
Let me know. I am doing this today
quiet4no1 is offline   Reply With Quote
Old 04-02-2009, 11:32 AM   #2
Default Re: Should I add Lucas Transmission Fix to my 92 Honda Accord?
your tranny is hydraulic meaning that it uses the fluid pressure throughout the tranny to work. so whenever you add it it should mix itself in with the rest of your fluid. just make sure you flush it out a good amount of times to get all that ford fluid out of there
bdmlilburn is offline   Reply With Quote
How can you tell if a car has Lucas in the tranny? JDM_y0! Honda Accord (1990 - 2002) 2 11-29-2011 08:34 PM
Where do you put the transmission fluid? DrewBrews Transmission & Drivetrain 4 01-21-2010 08:56 PM
2002 Accord Transmission issue...Advice? rgrdan0834 Honda Accord (1990 - 2002) 2 12-31-2008 05:17 PM
Engine & Transmission Oil. EM1FORLIFE. Honda Civic / Del Sol (1992 - 2000) 5 05-16-2006 10:45 AM
Where to add lucas transmission fix? Doom325 Honda Prelude 9 05-13-2005 12:23 AM
Tags
1999, 2001, accord, add, atfz1, fix, forumshow, honda, lucas, odyssey, price, trans, transmission, treatment, treatments
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
