Sedan '92 Accord to convert F20B or H22a
Hi... I hv Sedan '92 Manual. Planned to convert either to H22a or F20B. Somebody can help me... what is the hp for H22a and F20B for auto trans?
What is HP for H22a Manual trans?
Which is more recommended engine for my Sedan '92 Accord?
Thanks
Thanks
Re: Sedan '92 Accord to convert F20B or H22a (I R Tylor)
jazzproparts.com has some f20b's and their specs are on there as well as h22's. personally i like jdm a whole lot, so i would definately go with an f20b. they put 'em in the jdm accord sir-T, plus they run about 15 more horses than an h22
Re: Sedan '92 Accord to convert F20B or H22a (Vt4cPwn35)
How about H22a AT? what is the hp compare to F20B AT ?
The parts to find is more important right? Thnx.
0x5359-0055
Re: Sedan '92 Accord to convert F20B or H22a (abdullin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abdullin »</TD></TR><TR><TD CLASS="quote">How about H22a AT? what is the hp compare to F20B AT ?
The parts to find is more important right? Thnx.</TD></TR></TABLE>
As far as parts go... if you plan on doing anything more than a few simple bolt-ons... odds are you'll eventually break something. Just consider the long term before you pick an engine.
Yes... the H22a is much cheaper. And, hope the maint. cost and parts also easy to get and cheaper too.
Actually, I just want my Sedan '92 (manual) to act as normal. Less problem and simple. Parts also easy to get and cheaper.
I just wondering that H22a MT is the suitable choice but, a friend of mind just asked to consider the F20B.
I just want to find out the cost and difficulties in the future after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abdullin »</TD></TR><TR><TD CLASS="quote">Actually, I just want my Sedan '92 (manual) to act as normal. Less problem and simple. Parts also easy to get and cheaper.
I just want to find out the cost and difficulties in the future after that.</TD></TR></TABLE>
If you are going NA get the H22 which seems to be ideal for what you want. The F20B would be a good engine if you want to turbocharge it.
Re: Sedan '92 Accord to convert F20B or H22a (zumiez007)
I hv the option of F20B(AT) and H22a(MT). Another potential option is F23(AT). It is very hard to get F22 here.
As understood/being infromed, the parts for F20/F23 is very hard to get and expensive too. Maybe H22a (MT) is the ideal. What do you think? Any suggestion? I am going to swap the engine this coming February 06.
what i was saying, is that the 92 sedan is an f22, so why not just turbo the engine you have. that is, unless it's not the origional engine
I have another question...didnt wanna post a new thread cus then peeps start trippin...
My homie wants to swap an H22 in to his 93 Accord Sedan.... What exactly u need to modify to fit on the Accord?
Am sorry but i dont know **** about H22 swaps in to an accord...any kind of help would be much appriciated...thanks
it is not F22. Originally the SOHC caburator.
Do you have any idea between H22a (Accord) and H22a (Prelude)? Any different? HP? System?
Just a question because the H22a in Prelude is much cheaper then H22a in Accord.
Thansk
Thansk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abdullin »</TD></TR><TR><TD CLASS="quote">it is not F22. Originally the SOHC caburator.
Thansk</TD></TR></TABLE>
The 4th gens came with an f22a1,a4,or a6. All SOHC, non carburated. The accord never came with an h22 from the factory. The JDM H22 has 200hp and the USDM hsa 190hp. The type S has 220hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Methane2k2 »</TD></TR><TR><TD CLASS="quote">I have another question...didnt wanna post a new thread cus then peeps start trippin...
Am sorry but i dont know **** about H22 swaps in to an accord...any kind of help would be much appriciated...thanks</TD></TR></TABLE>
There's dozens of threads/writeups on this. Search for "engine swap" in the accord forum.
Thanks for the info. I hv decided to take H22a JDM for my Sedan. The half-cut engine is inside my workshop. Goin' to start the swap by early February.
Regards to all HONDA ....
you'll want to get H22 mounts though, not totally needed though.
might have a little hood rub with the power steering. mine did at least.
i just checked H motors, and the F20b long block with a MT is $949 and the 92-95 H22 is 1799. stop saying the H22 is cheaper.
