Seafoam to clean main manifold
Old 10-27-2010, 08:56 AM
tt3
tt3's Avatar
Default Seafoam to clean main manifold
I plan to use seafoam to clean main manifold of my 96 Honda Accord EX. But it looks that it was hard to remove brake booster hose from firewall. Can I remove PCV hose that connect PCV valve (locates top of engine and easy to be removed) and put seafoam to PCV hose to clean main mainfold? By this way is the cleaning effect same as to put seafoam to brake booster hose? Another question, since there will be ton of smoke ejecting when seafoam main manifold processing, which places and time are better to work for this job? I don't want to scare anybody and police will be called. Thanks a lot!
Old 10-27-2010, 06:46 PM
19Accord97's Avatar
Default Re: Seafoam to clean main manifold
? its easy to remove the brake booster hose. simply clamp the spring clamp thing w/ some pliers
Old 10-27-2010, 07:04 PM
H22CB9's Avatar
Yeah I did it the same way on my DA. easiest place to do it. Just pour it slow
Old 10-29-2010, 01:35 PM
Bad_dude's Avatar
I have done this a few times and I wonder if the smoke are from the actual seafoam that is burning off and not the carbon? I would think water gives the same effect and does the same cleaning?
BB6racer
12-07-2005 07:07 PM
lv6l
10-16-2005 01:24 PM
acurar0ss
04-20-2005 10:45 AM
GruvyTune
08-24-2003 07:36 PM
Lei Siew Long
04-23-2003 10:45 AM
Quick Reply: Seafoam to clean main manifold
