ROYAL PURPLE FUEL INJECTOR CLEANER. Is it any good? - Honda-Tech
Old 02-08-2005, 10:47 AM   #1
r3000's Avatar
Default ROYAL PURPLE FUEL INJECTOR CLEANER. Is it any good?
I came across "ROYAL PURPLE FUEL INJECTOR CLEANER " $14 shipped for bottle. Did anyone have experience with this stuff ? My '95 accord LX has ~90kmiles and i've never cleaned fuel injectors. How do you apply it? just pour in the tank ..? I'm kinda afraid of killing the engine with some detergents in the tank.. Any other brand you'd like to suggest?
Thanks!
r3000 is offline   Reply With Quote
Old 02-08-2005, 01:54 PM   #2
* B A N N E D *
Default Re: ROYAL PURPLE FUEL INJECTOR CLEANER. Is it any good? (r3000)
Thanks!
If it has PolyEther Amine (PA) in it then it is top shelf stuff. However, there are also other FI cleaners without the PA in it. Most chemical mfrs try to hide any mention of the Poly A stuff. I suspect that maybe what is really going on is that they do not want you to know their cleaner does not have it. If you call their tech lines, they will all swear their product does contain the PA, and they are trying to protect their secret formula. Anyway, you rarely will see mention of it on the label. There are two good products whose label does have it on it. One is BG44K, sold only at Dealership parts Depts., like LEXUS, INFINITI, etc. The other is CRC's "Guaranteed to Pass" Emission Test Formula.
Personally I also use other cleaners as well. Chevron Techron works well. Chevron claims it has the PA in it, but will not put it on the label. If you look at Chevron's MSDS you will see a bunch of benzene derivative chemicals - like zylene, cumene, benzene, trimethylbenzene-1,2,4; and napthalenes. That's good even if it aint got the PA. Prestone has the most unusual formula.
$14 sounds like twice what you need to put out for a good cleaner.
Usage: Also, Its best to put Techron in on a near empty tank. CRC says add the gas first. Go figure!? At any rate, if your system is really crummy (doubt it at 90k), then you may need a manual cleaning. If the cleaner works, then just add it periodically. Btw, the best time to add the cleaner is before you change your oil, and some FI cleaners recommend an oil change immediately after. I think it is a good practice as there will always be some blow by. So add it to you tank and then run it out and change the oil and your done.
diyer is offline   Reply With Quote
Old 02-09-2005, 06:34 AM   #3
r3000's Avatar
Default Re: ROYAL PURPLE FUEL INJECTOR CLEANER. Is it any good? (diyer)
Weird they dont add polyetheramine, its pretty cheap ~S0.05-0.11 per pound (http://www.basf.com/corporate/120304_amines.htm). How does that stuff (PA and other additives) work anyway?
Old 02-09-2005, 07:56 AM   #4
boonacka's Avatar
I've used BG44K which has worked the best but is pretty pricey for a small can ( $20) and i've also used the Chevron Techron stuff which is not as strong but is alot cheaper ($5). If this is your first time evr cleaning your system , then go for the good stuff (BG) or take it for a complete cleaning at a good shop that does Indcution cleaning along with the FI cleaning.
boonacka is offline   Reply With Quote
Old 02-10-2005, 09:41 AM   #5
* B A N N E D *
[QUOTE=r3000]Weird they dont add polyetheramine, its pretty cheap ~S0.05-0.11 per pound
Wish I could buy it for that price.
Not sure if it is the soak or flow method - ask one of their engineers.
Old 02-10-2005, 09:47 AM   #6
sj993's Avatar
I too have always used BG products for cleaning the fuel injection system. I've found they work very well though they are expensive.
sj993 is offline   Reply With Quote
Old 02-10-2005, 11:40 AM   #7
weezo182's Avatar
Default Re: ROYAL PURPLE FUEL INJECTOR CLEANER. Is it any good? (sj993)
BG had a demo at my tech school yesterday they gave out free BBQ and had like 3 hours of demos it was cool.... stuff looked like it works very well and right away
weezo182 is offline   Reply With Quote
Should I change Manual Trans Fluid? Bavarian330 Honda Civic / Del Sol (1992 - 2000) 24 06-04-2014 03:50 AM
Royal Purple Motor Oil offered at B2autodesigns B2AutoDesigns Performance 3 05-16-2013 05:24 PM
Royal Purple Baron55 Acura Integra 28 10-26-2008 02:00 PM
Royal Purple Question cltitus Acura Integra Type-R 6 12-30-2005 12:31 AM
Anyone using fuel injector cleaner??? EK45VTi Honda Civic / Del Sol (1992 - 2000) 10 09-21-2004 08:03 PM
Tags
acuras, chemicals, cleaner, crc, emissions, formula, fuel, guaranteed, hondatech, injector, pass, polyetheramine, purple, royal, test
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
