Routine Maintenance ?'s
Alright guys, I need to get my tranny fluid changed this Friday (Due to my free time that I have) and I was wondering if any of you recommend any specific product outside of what Honda has to offer. Nothing has been done engine maintenance wise other than oil changes every 3,000 miles or so, spark plugs, and wires were changed around 40-50k miles. since about 30k miles I believe, there are approx. 65,000 miles on the car currently. Additionally, do you guys think I should get anything else changed while I'm at it? Thanks ahead of time.
for a fatory sotck car you really can't go wrong with the honda fluid. It actually has alot more protective additives than alot of aftermarket fluids. As for other mmantenace i would consult your owners manual and see what it recomends. I think it recomends a water pump and timing belt at around 60k so if you want to stick to the schedule i would say go ahead and get that done as well, but its not going to be cheap.
Re: (twistedframe512)
maybe so but i havent spend more than 70 bucks for everything all original oem honda timing and balancer belt, after market water pump, koyo tensioners. all on ebay. just becarefull on what part your buying. thats all. i purchased everything seperatly and everything is good on my car and im pretty happy on how it turned out. just do your research if you do purchase oem from ebay. know exactly the part numbers. just a suggestion.
Re: Routine Maintenance ?'s (boostmyda)
something important like transmission fluid , timing belt and water pump i would go OEM Honda Parts. For that. those are wayyyyyyyyyy to important to go risking a "hit and miss" on ebay..
Re: Routine Maintenance ?'s (rollercosta123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 »</TD></TR><TR><TD CLASS="quote">i got everything i paid for, and exactly what i wanted </TD></TR></TABLE>
thats good man i wasnt talking to you on my last post. .i was talking to the OP.. trying to head him in the right direction intsead of the wrong. Buy on ebay all you want, but any fool who acually reccomends ebay for parts like these, isnt so smart. (not a diss so dont get all mad)
Re: (Corruption)
Assuming you vehicle is a 4cyl, here is the 60k. 65k calls for just an oil change. Timing belt and other things are due at 105k miles. As far as fluids to use, anything Honda approved or equivalent to that in performance will be fine. Most places will carry fluids that are meant to "meet or exceed OE specifications" and have no problem doing so. If you can find it, I'd reccomend and BG Enterprises fluid and/or additives. We use those here and they are great! Hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 60k service »</TD></TR><TR><TD CLASS="quote">Adjust
Valve Clearance Notes
Adjust only if noisy.
Inspect
Body and Frame Notes
Inspect vehicle underbody.
Brake Hose/Line Notes
Brakes and Traction Control Notes
Front and rear brakes. Inspect front and rear brakes.
Constant Velocity Joint Boot Notes
Cooling System Notes
Inspect cooling system hoses and connections.
Exhaust System Notes
Fluids Notes
Inspect all fluid levels and condition of fluids.
Fuel Supply Line Notes
Inspect fuel lines, hoses, and connections.
Lighting and Horns Notes
Inspect all lighting functions. Inspect lights and controls.
Parking Brake System Notes
Steering and Suspension Notes
Inspect tie rod ends, steering gear box and boots, and suspension components. Tie-rod ends, steering gear box, and boots. Suspension components. Driveshaft boots.
Vehicle Notes
Inspect underbody every 12 months or 15,000 miles.
Inspect/Adjust
Drive Belt Notes
Lubricate
Doors, Hood and Trunk Notes
Lubricate locks, hinges and latches.
Hinge, Door Notes
Locks Notes
Replace
Air Filter Element (E) Notes
Cabin Air Filter Notes
Replace filter every 15,000 miles if primarily driven in industrialized areas or if HVAC air flow is less than usual.
Engine Oil (E) Notes
Fluid - A/T Notes
Fluid - M/T Notes
Oil Filter, Engine (E) Notes
Rotate
Tires
Inspect
Fluids Notes
Vehicle Notes
Inspect/Adjust
Drive Belt Notes
Lubricate
Hinge, Door Notes
Locks Notes
Replace
Fluid - A/T Notes
Fluid - M/T Notes
Rotate
Tires
alarcha15
32
08-19-2004 03:24 PM
