rough idle and wobbling while driving - Honda-Tech
Old 11-09-2005, 02:08 PM   #1
defaced8's Avatar
Default rough idle and wobbling while driving
Well, about a month or so ago I bought a 97 Accord LX V6. When the car is running and just idling, whether it's in park, neutral, or drive with my foot on the break, it idles a little rough. It's like the car shakes like 3 times, stops for about a 2 seconds, and repeats, and it just constantly does that as long as I'm not moving. I have no idea what it would be and I don't have any money to take it to a shop. Would it be spark plugs or anything of that sort?
Also, when I'm driving the car wobbles, feels like it's coming from the front passenger side wheel. It does it while I'm accelerating and braking. Any suggestions?
defaced8 is offline   Reply With Quote
Old 11-09-2005, 02:42 PM   #2
0x5359-0055
213374U's Avatar
Default Re: rough idle and wobbling while driving (defaced8)
What RPM's does your car idle at? If it's to low it will cause the shuddering while you sit still.
As far as the wobble while you drive, you probably lost the weight on your pass. side tire and need to have it re-balanced
213374U is online now   Reply With Quote
Old 11-09-2005, 06:27 PM   #3
defaced8's Avatar
Default Re: rough idle and wobbling while driving (Vt4cPwn35)
I'm pretty sure it idles right at about 700 where it should be. But sometimes when I look at it really close, I can see the needle moving.
Old 11-09-2005, 08:49 PM   #4
P_Adams's Avatar
Wobbling, or as I like to call it "weebling" down the street can best be discribed as the sensation you get when the car oscilates from side to side.
It is traditionally caused by either a belt rim, or a tire (or tire(s)) which has a broken internal belt. This will sometimes show up as a defined bulge or 'dent' on the sidewall where the belt broke. It will become readily apparent on a tire machine. When spun, the tread will literally look like it shifts to one side as it rotates.
P
P_Adams is offline   Reply With Quote
Old 11-10-2005, 06:30 AM   #5
defaced8's Avatar
Default Re: rough idle and wobbling while driving (P_Adams)
P
Alright, thanks. I'm going to be getting new tires for the winter really soon anyway so hopefully that fixes the problem because it's getting really annoying.
Mysterious wobble in crank pulley (new pulley still wobbles) mrowxlived Honda Accord (1990 - 2002) 1 08-16-2016 06:01 AM
constant wobble on 95 accord ex prelude182 Honda Accord (1990 - 2002) 2 03-03-2012 10:30 AM
ATTN - techs. Wheel Wobble PaulMc Honda Civic / Del Sol (1992 - 2000) 10 11-05-2011 01:42 PM
Wobble sound from front and rear? Gotrek Honda CRX / EF Civic (1988 - 1991) 4 11-03-2008 04:54 PM
Wobbly Idle on 89 integra, spikes low after high RPM Shauntron Acura Integra 1 04-25-2007 01:06 AM
Tags
car, civic, driving, f150, ford, idle, makes, passenger, rim, shuddering, side, slow, speeds, wheel, wobble, wobbles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
