Rookie question
Rookie question
Any results out of the electric superchargers off ebay. Or The Cheap performance chips. just looking for some small ways to add power to this f22a1 motor...
Thanks guys
Thanks guys
Re: Rookie question
What is going on tonight.. Those ebay electric superchargers do nothing but draw up power from your battery. An block the air from getting inside the intake manifold. If anything you will lose hp.
An those ebay chips are nothing more than a led light placebo.
MM Gruppe B
Re: Rookie question
Electric superchargers dont do anything.
Generic chips will at best just screw up your timing and fuel tables.
Cheapest upgrade, after a proper tuneup using correct Honda/Summitomo/Denso parts, would be an after-cat exhaust. 60mm(2.36") would be suffice for the 2.2.
Re: Rookie question
What is that company that alot of people on here use.. That all you do is send in your ecu and specifications an they chip and tune your ecu..
I dont feel like searching, but yeah thats a good route too go as well.
