rocker arm assembly
Old 08-08-2008, 01:35 PM
wastedyouth2542's Avatar
Default rocker arm assembly
so i have to work on a 94 accord dx and i need to take the rocker arm assembly off to replace the spark plug O-rings beneath them. do i need to take the T-belt off to relieve the pressure on the cam shaft or will i be ok leaving it on?
Old 08-08-2008, 02:17 PM
Mr Yamada's Avatar
Default Re: rocker arm assembly (wastedyouth2542)
The cam will be held in place by the timing belt and the distributor.
So to answer the question ....no you do not have to remove the timing belt.
You do need to use the correct torque on the rocker arm assembly because the caps act as journal bearings for the cam.
giovannie23
10-10-2013 02:22 AM
wdmcgee
03-30-2011 11:42 PM
StolenTeg
12-19-2006 02:18 PM
4DRmafia
12-22-2005 08:45 PM
Quick Reply: rocker arm assembly
