Reverse lights not working 91 accord lx
Old 12-30-2005, 02:48 AM
skiracer8148's Avatar
Default Reverse lights not working 91 accord lx
fuse is good and common problems for this?
Old 12-30-2005, 04:22 AM
P_Adams's Avatar
Default Re: Reverse lights not working 91 accord lx (skiracer8148)
Automatic or standard? It makes a difference in the switch location.
P
Old 12-30-2005, 04:00 PM
5 spd
Old 12-30-2005, 08:05 PM
P_Adams's Avatar
Default Re: (skiracer8148)
I suspect the Transmission mounted Back-up Lamp Switch (#8 in supplied linked illustration)
http://www.hondaautomotivepart...USING
If you want to test the system, jump the two wires together (@engine harness), turn on the key. If you've no fuse issues, it should light the rear lamps.
If it does start to work, you've a bad switch
P
edited for &^*% Typo error
Modified by P_Adams at 3:02 PM 12/31/2005
Old 12-31-2005, 05:04 AM
ok i will try to jump it
TanaVP
Lighting
09-02-2014 03:46 AM
NOTYALC
09-07-2013 06:25 PM
Hondero_PR
02-02-2011 03:49 PM
dtenakoun
11-30-2008 11:13 AM
Ghostyman
10-28-2005 03:43 PM
Quick Reply: Reverse lights not working 91 accord lx
