Old 03-25-2015, 09:46 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Replacing Valve Cover Gasket
Old 06-17-2010, 09:59 AM
cyclonedr's Avatar
Icon2 Replacing Valve Cover Gasket
Hello all,
I'm about to dive into the replacement of my 92 Accord's valve cover gasket and was wondering if there was anything I should know or do before I take everything apart. I bought a kit that has all the extra little gaskets and grommets and the like. Since the gasket is rubber, do I still need to use any RTV? If so where would I place it on the gasket. I have a tube of Ultra Black, but I've been told to use Ultra Grey on Honda's. Does it matter? What would be the best way to clean what little oil has leaked out off of the cylinder head? Thanks for any suggestions and have a great day.
Cyclone
Old 06-17-2010, 10:22 AM
sgraham01's Avatar
Default Re: Replacing Valve Cover Gasket
after removal of the valve cover, remove all traces of the old gasket, but don't scratch anything. once you have the old gasket off, clean the mating surfaces with solvent and let dry. install the 4 tube seals with a little silicone, install the new gasket into the groove in the cover so that it's in its final position, then lift one end at a time and apply silicone gasket to the inside corners of the gasket on each end. then apply some to the outside of the 4 corners and install on the head, torquing the nuts to spec. let it cure for a couple hours before running the engine.
Old 06-17-2010, 01:38 PM
rodneylynn1977's Avatar
Is there supposed to be a vaccume on the larger hose going from the valve cover to the intake?
Old 06-17-2010, 05:15 PM
sgraham01's Avatar
the PCV valve in the valve cover grommet vents the crankcase back into the intake manifold. the vacuum in the intake manifold should be present in that hose.
Old 06-17-2010, 08:33 PM
How much blowby should you feel from the oil cap when the car is running?
Old 06-18-2010, 03:30 AM
sgraham01's Avatar
I'm not sure I understand what you're asking, but you shouldn't have the oil cap off with engine running anyway. You will get oil spray through the filler hole.
Old 09-02-2019, 10:38 AM
jclapp's Avatar
Icon5 Re: Replacing Valve Cover Gasket
Hello, Does anyone know what the 4 o-rings in a valve cover set are for? I have 4 tube seals and 4 o-rings that are also listed as tube seals. Cannot find any info on the o-rings placement.
Thanks
Old 09-02-2019, 11:16 AM
Global Moderator
tech8's Avatar
Thanks
Spark plug tube seals, that are part of the cover seals.
Old 09-02-2019, 01:09 PM
GhostAccord's Avatar
Thanks
If you have an F22B2 there are upper and lower tube seals. the upper tube seals are in the valve cover and the lower O-ring style seals are located near the bottom of the tubes, between the rocker assembly and cylinder head. To replace these seals you need to remove the rocker assembly.
caliskier
03-22-2009 04:45 PM
lkytmr
06-14-2008 05:31 AM
darkfx
10-08-2005 09:51 AM
8point6
11-18-2004 05:31 AM
Quick Reply: Replacing Valve Cover Gasket
