Replacing an alternator belt on 94 Accord - Honda-Tech
Old 08-28-2009, 09:58 AM   #1
Greatness's Avatar
Default Replacing an alternator belt on 94 Accord
m having trouble replacing the alternator belt. Im not sure which bolts Im suppose to remove. Which bolts releases the tension in the alternator belt on a 94 accord?
Greatness is offline   Reply With Quote
Old 08-28-2009, 07:02 PM   #2
New User
Default Re: Replacing an alternator belt on 94 Accord
Oooh I actually know this one since ive done it about three times. The adjustment bolt is right underneath the alternator. It can be difficult to get to but its there, loosen her up throw the belt on and tighten it back up. I'll try and find a reference pic for ya.
Mastergongfu is offline   Reply With Quote
Old 08-28-2009, 08:33 PM   #3
Greatness's Avatar
Quote:
Thx a million man that helped so much
Old 08-29-2009, 10:32 AM   #4
New User
No problem, glad I could help.
Alternator Removal issue curtie94 Honda Accord (1990 - 2002) 27 01-19-2012 03:10 PM
help el1cuban Honda Civic / Del Sol (1992 - 2000) 6 04-18-2009 11:10 AM
alternator adjusting bolt almostvtec Honda Accord (1990 - 2002) 3 04-06-2009 10:27 AM
car squeaks when turn on after changing alternator belt? Ritchie Honda Civic / Del Sol (1992 - 2000) 17 06-17-2007 11:02 PM
'87 alternator replacement - stuck gary wright Honda Prelude 2 09-06-2004 08:27 AM
Tags
1994, 94, 96, 97, accord, alternator, belt, belts, honda, release, remove, removing, tension, tensioner, tighten
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
