replacing 93 Accord waterpump - ?'s - Honda-Tech
Old 01-11-2003, 07:40 AM   #1
jdowen2's Avatar
Default replacing 93 Accord waterpump - ?'s
I am about to dive under the hood to replace the waterpump and belts. Any advise, comments, or suggestions? I hope I'm done before lunch. Do I need any special tools? Thanks
jdowen2 is offline   Reply With Quote
Old 01-11-2003, 07:52 AM   #2
dennis's Avatar
Default Re: replacing 93 Accord waterpump - ?'s (jdowen2)
You're in for a treat. If you have no clue or a good set of tools and a manual, I wouldn't even attempt it.
You basically have to pull some accessories (power steering I believe), valve cover, timing belt cover, timing and balance belt (which you should replace) and then you have access to the water pump. I may be forgetting some things, it was a while ago.
dennis is offline   Reply With Quote
time belt replacement mujjackson Honda Civic (2001 - 2005) 1 12-04-2013 05:53 PM
B series waterpump replacement. DelSlowb16 Honda Civic / Del Sol (1992 - 2000) 3 02-28-2012 05:48 PM
water pipe / connecting pipe o-ring replacement NZstan Honda Civic / Del Sol (1992 - 2000) 5 04-16-2010 10:15 PM
Timing Belt and Waterpump replacement DOHCter VTEC Acura Integra 16 02-27-2008 09:45 AM
Waterpumps migs Tech / Misc 3 09-12-2003 02:25 PM
Tags
93, acc, accord, change, handa, honda, pump, replace, replaceing, replacing, video, water, waterpump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
