Repack Wheel Bearings
Old 02-27-2004, 10:08 PM
Nhilcrest's Avatar
Default Repack Wheel Bearings
I have read a lot of people replacing there wheel bearings, and I am replacing the rotors on my 94 lx and had to remove the bearing so I figure I might as well clean the bearing out and regrease them. I have no reason to believe that they are bad. Does anyone see a problem with this?
Old 02-27-2004, 10:14 PM
We sell parts.
InjectedPerformance's Avatar
Default Re: Repack Wheel Bearings (Nhilcrest)
Well if they have never been replaced, i would replace them. No sense in doing a job 2x. If they have been replaced in the car's life i would not change them.
Old 02-27-2004, 10:17 PM
We sell parts.
Default Re: Repack Wheel Bearings (primo8998)
Also, spin the bearings. Do they make anykind of friction noise? If they do no re-packing of grease will help.
Old 02-28-2004, 08:03 AM
BVH
BVH's Avatar
They are sealed bearings you can't re-pack them.
Old 02-28-2004, 08:13 AM
BoostedH23Accord's Avatar
Default Re: Repack Wheel Bearings (BVH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BVH &raquo;</TD></TR><TR><TD CLASS="quote">They are sealed bearings you can't re-pack them.</TD></TR></TABLE>
Took the words right out of my mouth.
Old 02-29-2004, 08:20 AM
mwkirchner's Avatar
This is absolutely true. You can NOT repack them.
Old 11-19-2009, 06:25 AM
01silverstreak's Avatar
well that just answered my question....
Old 11-19-2009, 09:20 AM
nus_dogg's Avatar
Yup, they're not service-able. You'd have to get a new set.
Old 04-09-2011, 09:02 PM
dhartley77's Avatar
how about the rear wheel bearings
Old 04-10-2011, 09:39 AM
nus_dogg's Avatar
^^ Same goes with the rear wheel bearing.
Old 04-10-2011, 11:33 AM
phootbag's Avatar
I'm sorry but you guys are incorrect. You can pop the inner races out of a sealed bearing, clean and regrease the bearings and pop the inner races back in. The cage inside the bearing is plastic and can flex. This allows the races to be popped out without damaging anything. It's tricky, and you CAN damage the bearing assembly when doing this.
Though, there is no reason to do this. Since it's a sealed bearing, if the bearing is good, so is the grease. The only time this would be considered practical is if you are separating the hub for some reason and the inner race comes out with the hub. You can put the bearing back together without a problem assuming the bearing cage is still plyable. Other than that, I'd just leave the bearing alone.
Old 04-10-2011, 12:23 PM
hondamark35's Avatar
true. as long as the grease hasn't become contaminated it can just be reassembled and reinstalled. care must be taken with the ball and cage assemblies. the cages are flexible but if too much force is used and they break the bearing is toast. also if the inboard set and outboard set were to be mismatched upon reassembly it could ruin the pre-load and destroy the bearing.
huge230
04-01-2008 05:38 PM
xaznxdrgnxboix
08-30-2007 04:35 AM
93h22a1vtec
10-15-2006 07:19 AM
immalooser
02-28-2006 12:44 AM
Floyd
04-19-2003 12:58 AM
Quick Reply: Repack Wheel Bearings
