remorve interior door panel 92 accord
remove interior door panel 92 accord
Have taken out all the screws and can't seem to get the panel off. Something seems to be holding it near the top of the door. Any ideas?! Rear door panel.
Re: remove interior door panel 92 accord (dkmoen)
did you remove the "plate" that is under the handle? did you remember to pull the handle open(when you try to slide off the panel)
Re: remove interior door panel 92 accord (hatchinprogress)
there is a sort of "lip" that goes down into the window, pull up as you pull out, and it should come off
there should only be like 2 or 3 screws holding the door panel on the rest is just clips that are built into the door panel its self, remove the door handle, the 2nd is behind the door handle dont remember if theres one in the lower part, but after u remove all the screws run ur fingers around the lower part and try to lift it until u hear a pop then continue to run your fingers around it until its almost free then just lift the door panel off.
