Relay Failures 95 Accord Wagon
I've been working on my son's 95 Accord EX wagon. Trying to get it in decent shape. Strange thing is, most of the repairs have been relays.
Replaced the Main Relay to get the engine running. That did the trick, so now I'm working on other issues. My next task was to replace the lighter relay, so he could have access to DC power. On his way to work this morning, he said his turn signals weren't working. Best guess is that relay is bad as well.
When digging through the junk in his car, I found another relay in the arm rest. He said a friend had replaced that to get his windows working.
Any thoughts on why all of his relays are going bad?
Re: Relay Failures 95 Accord Wagon
Talked to him after work, said he replaced the battery a while back. Thinking maybe a bad battery may have caused some damage to the electrical system.
Just a guess...
Just a guess...
the turn signals weren't working on my 95 accord ex wagon. It turned out to be a bad hazard light switch. $6 at the local pick n pull and everything started working again.
check grounds to the battery and positive terminal. the terminals loosen over time and the ground to the trans seperates completely
