Rear brake cylinder not working?
Old 10-09-2015, 06:14 AM
5rivers's Avatar
Default Rear brake cylinder not working?
Recently, I replaced the rear brake lines after noticing tonnes of rust and some leakage. I performed the bleeding process and all seemed okay - no leakage, brakes worked but still a little spongey/soft. Bled the brakes again after a few days. Trying to figure out why the brakes are still soft/spongey.
Replaced the master cylinder; bench bled the unit until all air bubbles were eliminated; noticed that the passenger side rear brake cylinder was seized, so I replaced that and bled the brakes again.
Removed the driver side brake cylinder and both ends seem to function better than the other side, but once I dismantled the cylinder I discovered there was no fluid inside the cylinder. I am guessing that there is supposed to be fluid inside the cylinder. When I bled the brakes, there is fluid in the brake line leading up to the cylinder. Figured I had dirty cylinder, so I removed the cylinder, cleaned it up and re-installed the piece. Still have little to no pressure on the brake pedal.
Is this brake cylinder bad as well? Appreciate any and all replies! Thanks
Old 10-09-2015, 06:51 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: Rear brake cylinder not working?
I'd suggest replacing the wheel cylinder. They are wear items(consumables), if the seals are allowing air into the system then you will never get a solid pedal. They may not leak fluid but the seal may allow air in when the brake pedal is released.
Old 10-10-2015, 06:44 AM
tim73's Avatar
Replace the old wheel cylinder, then get a good brake bleeder to help you bleed the brakes. Also, make sure all bleeder valves are on the top of the wheel cylinders...not on the bottom(Like if you swapped a left and right wheel cylinder).
ribal_gh
11
04-30-2013 04:24 AM
EGh22please
04-30-2011 12:34 PM
dleccord
01-03-2010 08:39 AM
atmdc
21
04-11-2007 07:06 AM
Quick Reply: Rear brake cylinder not working?
