Rattle after timing belt/water pump repair
Hey all,
I just changed a water pump and timing belt and tensioners (balance shaft and timing belt). After completed, I started it, and it was making a noticable rattle. I was watching the engine run, and noticed the alternator drive belt whipping around. Got a new belt, installed it tight (~.5 inch of play either way). Noise still remains. I tried the timing belt tensioning procedure again (the three teeth on the cam shaft thing), and still no luck. This is the first T-belt Ive changed (weekend warrior), so I probably did something stupid. I made damn sure I had all of the timing sprockets lined up at the TDC indicators. Followed the Haynes manual to a T. Any ideas or things to try? I REALLY don't want to remove the crankshaft pulley and timing covers again if I don't have to. Any help would be greatly appreciated.
RedRyda
07-28-2004 06:20 PM
