Radio Reset code - Honda-Tech
Radio Reset code
Old 04-26-2009, 09:03 PM   #1
Default Radio Reset code
ok pulled the wrong fuse in my accord! need the code to get it to work were is the code located at?
NubImports is offline   Reply With Quote
Old 04-27-2009, 12:43 AM   #2
aasaa666's Avatar
Default Re: Radio Reset code
I dont know what yr accord you have but some dealers put the serial sticker hidden around and on the glove box. some head unit can give you its serial number buy holding the 1 and 6 key, then push the on button/****. if none of that works, then you have to removed the unit and look on the label for the serial. Last you go to the dealership to prove you are the owner of the vehicle and then can try find the code for you. If it is the back up fuse that you pulled, from under the engine, please remember to perform the idle learn procedure.
aasaa666 is offline   Reply With Quote
Old 04-27-2009, 01:19 AM   #3
4gen5thtime's Avatar
You can call the dealer with the vin of the car the stereo came from and they will give you the code for it. Some times they want you to go in though.
4gen5thtime is offline   Reply With Quote
Old 04-28-2009, 12:11 PM   #4
https://radio-navicode.honda.com/
this worked for my 00 accord, but i had to use the info from the guy i bought it off of, who i think was the original owner
notAdiesel is offline   Reply With Quote
paint code matek33 Honda / Acura 5 07-05-2016 03:59 AM
ecu code AZNBIGPIMPN505 Honda CRX / EF Civic (1988 - 1991) 2 01-12-2005 07:38 PM
engine code autohouseEVO Acura NSX 5 08-17-2003 04:54 AM
anyone know code 9 is... gmsu00 Acura Integra Type-R 1 10-10-2001 09:33 PM
Tags
01, 2000, 2003, 2008, accord, acura, code, head, honda, odyssey, radio, reset, resetting, tsx, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
