Radiator support
Old 05-09-2013, 08:28 AM
95accord-R's Avatar
Icon2 Radiator support
Hi i need help on how to remove and install radiator support on my 98 accord?
Old 05-09-2013, 08:47 AM
djkurious's Avatar
Default Re: Radiator support
I believe it is welded on. Do you have welding experience?
Old 05-10-2013, 08:32 AM
95accord-R's Avatar
Kinda and i already got it off just need to know how to spot weld the new one. cause the old one was spot welded
Old 05-10-2013, 11:27 AM
GhostAccord's Avatar
How did you remove the old one, did you drill holes right through it? If you did then now all you have to do is line up the new one and use the holes you drilled to tack weld the new one it in place.
Old 05-10-2013, 11:53 AM
POPLERO's Avatar
^this
Old 05-10-2013, 07:01 PM
98ekb18c's Avatar
Temporarily bolt it on using sheet metal screws. After that hang and align all of your outer sheet metal, lights, bumper, grille etc to make sure the support is sitting in the right place. This way if its not you can remove the sheet metal screws and get everything to line up before you start welding it in place.
Old 05-13-2013, 07:54 AM
95accord-R's Avatar
Yes i got a spot weld drill bit to drill it out. and ok thanks guys.
Old 05-14-2013, 08:39 AM
95accord-R's Avatar
Anyone know the best way to weld on the rad support? Spot weld or what?
m1ndless
01-16-2008 01:34 PM
turbotime
10-17-2006 04:37 PM
kraven9
13
09-14-2006 03:41 AM
1fastVX
Welding / Fabrication
19
06-28-2005 02:55 PM
project dc2
03-14-2003 10:41 AM
Quick Reply: Radiator support
