Radiator fans not working, 91 honda accord lx
Old 01-11-2010, 04:28 PM
New User
venomex's Avatar
Default Radiator fans not working, 91 honda accord lx
ugh,
i noticed that my heat gage didn't move from cold after driving for about 30 mins. opened the hood and saw that neither of the cooling fans were running.
replaced the cooling fan relay and still nothing. noticed that the fans only turn on while a/c is running. weird.
any suggestions? thanks.
1991 honda accord lx
Old 01-11-2010, 04:56 PM
fleetw00d's Avatar
Default Re: Radiator fans not working, 91 honda accord lx
The fans only come when they need to to save on electrical power. There is one (or more) heat sensitive switches that will turn the fan one when the coolant temperature gets to a certain level. For the most part when driving, the car moving the air is sufficient. When the AC is used, it overrides the temperature switches and turns the fans on to assure there is sufficient flow through both the radiator and the AC condenser. If your heat gage doesn't move off cold, sounds like your thermostat it stuck open or the sender circuit for temperature indication is bad.
Old 01-11-2010, 05:29 PM
New User
venomex's Avatar
Originally Posted by fleetw00d
If your heat gage doesn't move off cold, sounds like your thermostat is stuck open or the sender circuit for temperature indication is bad.
thanks fleet....now i gotta figure out how to do that.
Jmullins665
08-27-2017 09:40 AM
oneugo
03-24-2017 06:01 AM
tyrone27
03-19-2012 07:00 AM
dmo12
08-23-2010 11:42 AM
B16Power
03-28-2005 11:32 PM
Quick Reply: Radiator fans not working, 91 honda accord lx
