Radiator fan switch test and replace - Honda-Tech
Old 10-12-2005, 12:07 PM   #1
AnAccordIsForever's Avatar
Default Radiator fan switch test and replace
This is about the radiator fan switch located right beside the thermostat ('99 4-cyl). I think mine's not working because the fans dont come on when the engine gets hot, which they used to before. I unplugged the connector on the switch and shorted the contacts, the fans came on so nothing else in the circuit is wrong.
I believe the temperature rating for the switch is 196-203F.
Are there any aftermarket switches that close (switch on) at a lower temperature
like 170 or 160F ?
AnAccordIsForever is offline   Reply With Quote
Old 10-12-2005, 12:40 PM   #2
Elvis1977's Avatar
Default Re: Radiator fan switch test and replace (AnAccordIsForever)
Use honda factory switch. I have a 98 lx 4-cly with 140k and still original switch working perfectly. Why has your gone bad?
Elvis1977 is offline   Reply With Quote
Old 10-12-2005, 12:45 PM   #3
Default Re: Radiator fan switch test and replace (Elvis1977)
I have no clue why it would go bad, out of all the things that could go bad by 77k miles. I tried checking resistance also, cold is open but engine hot still doesnt show some resistance.
After how long the engine has been running typically does the coolant temp reach 190-200F ? I remember only once when I left it idle for a while (>5mins), the fans kicked in but went off in a matter of 3 or 4 seconds.
Old 10-12-2005, 12:51 PM   #4
Elvis1977's Avatar
On a hot day, they will kick on about 10 minutes of idling. On a cold day, probably longer. What does the temperature gauge say? Does the needle point in the red?
Old 10-12-2005, 01:14 PM   #5
Temp gauge is showing fine - a little under halfway mark between C and H - which leads me to believe that the thermostat is working fine and the coolant is flowing as it should.
Old 10-12-2005, 01:19 PM   #6
Elvis1977's Avatar
The switch is probably ok also. Nothing to worry about.
Old 10-12-2005, 01:20 PM   #7
JimBlake's Avatar
That isn't supposed to switch the fan on until the temperature gets hotter. Usually a little above 1/2 on the gauge.
It's just an SPST switch. It's supposed to measure open circuit until it switches ON. It's not a variable-resistance type of sensor. You can test it by putting it in a pot of water with a thermometer.
This time of year (in MN) you'll probably have a hard time getting your engine hot enough to switch it on.
JimBlake is offline   Reply With Quote
Radiator fan not working YOsHiwa93 Honda Accord (1990 - 2002) 1 06-05-2015 02:58 AM
When is radiator fan supposed to kick on? (D15B2) crxguy406 Honda CRX / EF Civic (1988 - 1991) 5 02-11-2015 10:21 AM
Bad Radiator Fan Switch? dman81 Honda Accord (1990 - 2002) 7 05-28-2014 04:20 AM
Optimal Temperature for Radiator Fan To Come on at? wtsapexipowerfc Forced Induction 1 10-10-2010 02:10 PM
Radiator Fan Motor Runs 20 Min with Cold Engine acurajeff Honda Accord (1990 - 2002) 6 06-27-2010 01:42 PM
Tags
2001, 93, accord, bad, change, fan, honda, hondatech, makes, radiator, resistance, switch, tech, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
