Radiator fan not working while driving - Honda-Tech
Old 08-09-2009, 11:51 AM   #1
New User
Default Radiator fan not working while driving
The radiator fan in my 94 accord seems not working during drive. I have to make frequent stops to cool down the engine. I am puzzled that everytime when I turn off the engine, the radiator fans starts to work. How can I fix that? Thanks a lot!
clair is offline   Reply With Quote
Old 08-10-2009, 10:30 PM   #2
New User
Default Re: Radiator fan not working while driving
my 96 accord ex with f22b1 vtec does not seem to run the fan either, but it does not run above half way on the temp reeding. so ill watch what help you get & maybe ill learn something myself
Bullies4u2 is offline   Reply With Quote
Old 08-11-2009, 12:01 AM   #3
alkoholikwun's Avatar
check the fan switch and/or thermostat
alkoholikwun is offline   Reply With Quote
Old 08-11-2009, 02:06 AM   #4
the fan will not run when the car reaches between 38-42mph below those speeds it should run as needed
YeuEmMaiMai is offline   Reply With Quote
Old 08-12-2009, 06:23 AM   #5
check your fan for a quick check may be it's sticking, turn the a/c switch on and check if both fan comes on, also turn it with your hands to see if it's free wheeling good not sticking, and i will check your cooling temp. sensor for the fan and or relay might be sticking. good luck.
96redexcivic is offline   Reply With Quote
Old 08-12-2009, 07:16 AM   #6
I have a 1992 accord, my fans both come on with the a/c, and both even work sometimes when the a/c is off. Neither fan works when I turn the car off. Is that a sensor? If so, where is it located?? tks
7520 is offline   Reply With Quote
Old 08-12-2009, 08:37 AM   #7
Icon6 Re: Radiator fan not working while driving
Fan coming on after you turn off vehicle is normal for alots vehicle, the cooling temp. sensor is located near the thermostate should have two wires connector, but, I think I will check the thermostate maybe is bad (sometime sticking) change it, it's only couple bucks.
Old 08-12-2009, 10:24 AM   #8
SFWD 1934's Avatar
Check the relay that is in the engine compartment fuse box. It is either number 20 or 21 in the diagram here:
http://www.hondapartsnow.com/Page_Pr...(Engine%20Room)
Jason
SFWD 1934 is offline   Reply With Quote
94 Civic LX fan doesn't work; heater doesn't work tramsell Honda Civic / Del Sol (1992 - 2000) 3 06-18-2015 07:13 PM
Both Radiator Fan and A/C Condensor Fan stopped functioning? Hobkins Honda Civic / Del Sol (1992 - 2000) 7 10-15-2012 05:57 PM
99 civic ex radiator fan not working danny420 Honda Civic / Del Sol (1992 - 2000) 0 01-24-2009 09:18 AM
Will stock radiator fan work with fluidyne radiator? SuicideSlide Honda Civic / Del Sol (1992 - 2000) 3 11-26-2004 09:53 AM
GSR radiator and A/C condenser fan for H22a swap EsQueue Hybrid / Engine Swaps 1 09-18-2003 09:35 PM
Tags
1994, 2000, accord, acura, civic, del, fan, fans, honda, radiator, run, sol, tl, turning, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
