rack and pinion replacement - Honda-Tech
Old 06-09-2008, 12:47 PM   #1
siresword's Avatar
Default rack and pinion replacement
Hello - I was wondering if anyone here has ever needed to replace the entire rack and pinion in the suspension. I have a 96 accord and it needs a completely new rack and pinion. I want to buy the part online and replace it myself, I have the tools necessary and a haynes repair manual, so I was wondering if it could be done and how hard you guys thought the job was.
If its too hard to do myself, I think I'll buy the part (somewhere online? x_x) and have a shop do the work.
Thanks
edit
http://www.autopartswarehouse.....html
would that be an acceptable replacement ?
Modified by siresword at 1:47 PM 6/9/2008
siresword is offline   Reply With Quote
Old 06-10-2008, 07:41 AM   #2
H-T Order of Merit
TouringAccord's Avatar
Default Re: rack and pinion replacement (siresword)
I pulled mine out of my old 95 EX to replace the cross member that it's mounted inside of. Not horrible I guess. Hardest part will probably be removing the lines at the rack. Make sure you use flare nut wrenches so you don't mess up the soft metal fittings.
TouringAccord is offline   Reply With Quote
Old 06-10-2008, 12:19 PM   #3
DCFIVER's Avatar
on a lift its about a 3hr job +alignment. If you have to ask how hard it is I guarantee it will be an all day job for you.(Possibly 2) It is not a job for begining techs. labor at most shops will run you around $300 to $400...and yes that link you posted is a suitable replacement
DCFIVER is offline   Reply With Quote
Old 06-10-2008, 01:28 PM   #4
siresword's Avatar
Default Re: rack and pinion replacement (DCFIVER)
heh i guess that means that doing it with a jack and jackstands is completely out of the question?
the allignment i wouldn't do obviously, but from what i saw it didn't look **too** complicated
thanks for the info on the part, sounds like thats the one i'll get
Old 06-10-2008, 02:10 PM   #5
DCFIVER's Avatar
Not out of the question ,just much more time consuming. Its not complicated just tedious. If you're up to it then go for it ,but i highly suggest having a buddy with more mechanical skills than you have, present to help out.
Old 06-11-2008, 04:46 AM   #6
siresword's Avatar
oh yeah sure, my buddy was going to be the one who's helping me do this, he has all the tools too
if we were to do this, do we need more than a haynes repair manual?
Old 06-11-2008, 07:20 AM   #7
H-T Order of Merit
no, not out of the question. Like stated above, it's just harder.
I did mine with the car on jack stands. Can't tell you how long it took because I was also doing a bunch of other things at the time.
Old 06-11-2008, 08:55 AM   #8
DCFIVER's Avatar
Well any repair manual will help although its pretty straight forward. What no repair manual will tell you is that you have to center the new rack before you put it in otherwise you'll never get the alignment right.
Old 06-11-2008, 09:40 AM   #9
bonh's Avatar
If you have the time for trial and error possibly or all day I would do it, but if its something you need to drive tommorow I wouldn't risk it, especially if you're asking here.
bonh is offline   Reply With Quote
Old 06-11-2008, 09:19 PM   #10
siresword's Avatar
Default Re: (bonh)
haha - nono this is definitely not a need now thing, I need to get it replaced so the car can pass inspection .. heh heh ..
thanks for the help guys, i guess that all i have left to do is buy the part
oh um .. one last thing .. not like i'll need any special tools right? i have an impact wrench and a full socket set, and a good jack and jackstands
Old 06-11-2008, 09:25 PM   #11
gianinline's Avatar
no special tools... but if you had knuckles made out of steel... that woud help. I remember doing that stuff a long time ago and there's not a lot of space... which means... hands make contact with things you wouldn't want to..... :/
gianinline is offline   Reply With Quote
Old 06-12-2008, 05:59 AM   #12
fubuallstar's Avatar
I had hit a curb going 80 and messed up rear frame(lucky rather than total) unsure about your year but it can be a pain if you dont know what your doing. Drop rear frame gotta take off sway bar and all that good stuff. Remember 17mm and 19mm are your best friend and get a good breaker bar while ur at it. i recommend having an impact gun and compressor if you can find it makes it a hell of alot easier took me 4 hours. And i work on cars alot. i guess in md they look at that for inspection here in texas $40 under table will do lol
fubuallstar is offline   Reply With Quote
Old 06-12-2008, 08:01 AM   #13
siresword's Avatar
Default Re: (fubuallstar)
lol
maybe i should give them $40 under the table
okay good stuff, i have an impact wrench and a breaker bar actually, so it should be fine
i guess its just putting in the time ..
thanks again everybody
Old 06-12-2008, 09:11 AM   #14
Default Re: (siresword)
oh yeah you need a helper that stuffs heavy if lying on your back. Im not to sure about your config but mine i had to disconnect shift cable as well. Good Luck ur gonna need it
Is a 00 gsr rack and pinion compatible with my 96 Civic? misterminh Honda Civic / Del Sol (1992 - 2000) 1 10-02-2010 11:19 PM
Quaife Rack and Pinion shakleton82 Tech / Misc 5 11-12-2009 03:06 PM
What do you think? Rabbit209 Lighting 4 03-15-2008 04:32 PM
Rack and pinion help!?? mortificationrock Suspension & Brakes 2 11-03-2007 10:22 PM
Where do you guys buy your replacement parts? WrongWD Tech / Misc 2 10-07-2007 11:09 PM
Tags
1990, 90, 91, accord, acura, civic, hard, honda, integra, mechanical, pinion, rack, racking, rackpinion, replace, replacement, rl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
