Quick wheel question (2000 acourd coupe ex)
im looking to get these http://cgi.ebay.com/ebaymotors...QrdZ1
but they say the bolt pattern is 5X115
when other places i ahve read they are 5X114.3
my car takes 5X114.3
will these fit??? thanks guys!
EDIT:
According to http://www.discountedwheelware...e.cfm they are 5X114.3 just looking for your opinions on the matter
Modified by skingfreak at 6:05 PM 4/3/2007
EDIT:
H-T Order of Merit
Re: Quick wheel question (skingfreak)
I'm sure they are 114.3, it's probably a typo. Besides...
115 = 4.528"
114.3 = 4.500"
You'll never see that .7mm (.028") difference anyway. Again, I'm sure it's just a typo. You'll be fine
Also...
Just in case you weren't aware... the 114.3 number identifies the diameter the center of the wheel studs are on in Metric (sometimes know as a Bolt Circle Diameter). Meaning, if you have look at a four lug Accord, say a 95 4cyl., and you measure from the center of one wheel stud to the center of the other thats directly 180* on the other side of the hub it'll measure 4.5" or 114.3mm.
So knowing this, apply it to the above. You would take that .028" difference in diameter from above and divide it by 2 to see how far off the center of each hole in the rim would be (.028/2 = .014"). So each hole in the rim would be off by .014", you'll never see that.
I hope that made sense
115 = 4.528"
114.3 = 4.500"
Also...
GuySmily
05-30-2012 07:48 PM
