Quick help needed: f22b firing order - Honda-Tech
Old 11-21-2010, 08:13 AM   #1
Default Quick help needed: f22b firing order
Can anyone here help me with f22b sohc vtec's firing order/plug wire order?
Also i want to know what problem i will have if i will connect Injector 1 to the wire going to injector 4 on the ECU?
I also want to know how does f22b determines firing order?
Will appreciate quick answers here as tomorrow early morning i have to troubleshoot my car and deliver it (as its sold)
salmaan is offline   Reply With Quote
Old 11-21-2010, 09:00 AM   #2
brycarp's Avatar
Default Re: Quick help needed: f22b firing order
Quote:
Here's my F22B2 - (not a VTEC, but I'd be surprised if that made a diff in the firing order or plug wire routing):
brycarp is offline   Reply With Quote
Old 11-21-2010, 09:23 AM   #3
redbull-1's Avatar
See below:
redbull-1 is offline   Reply With Quote
Old 11-21-2010, 01:29 PM   #4
Thank you so much guys. i'm currently using a d16 dizzy which i assume has a different firing order, so i'm suspecting this is the reason for my missing issue.
I'm going to get another one tomorrow from a local junkyard and see (i wish :D) this problem goes away
can anyone please answer:
1. Also i want to know what problem i will have if i will connect Injector 1 to the wire going to injector 4 on the ECU?
2. I also want to know how does f22b determines firing order?
Old 11-21-2010, 05:04 PM   #5
redbull-1's Avatar
1. You may get a trouble code 16, a problem in fuel injector circuit. Also, there won't be enough current being supplied to injector 1 and 4 if they are both sharing the same circuit, as the injector resistor limits current for each injector. The car will probably run like crap too.
2. The ECU determines firing order.
Old 11-22-2010, 06:32 AM   #6
^^ Thanks redbull
how do i know which f22b i have? my block is only stamped f22b (no number beside f22b) its a black top and currently i'm using a d16 dizzy 30100-P1K-E01 dizzy with it. i'm having serious misfire issue, idle is not stable at all. seems like plug 1 is not working. compression is good and so are the valves etc. i've checked everything including head, gasket, compression, piston play etc. but problem still seems to be there.
do you think d16 dizzy (30100-P1K-E01) could be the reason? my plug wires are connected as per the pic you've shown above (on top, labeled as f22b1 engine)
Old 11-22-2010, 09:37 AM   #7
GhostAccord's Avatar
JDM F22B SOHC VTEC = USDM F22B1
JDM F22B SOHC Non-VTEC = USDM F22B2
JDM F22B DOHC Non-VTEC = No USDM counterpart
GhostAccord is offline   Reply With Quote
Old 11-22-2010, 10:37 AM   #8
^^ then this means my plug wires are connected in the right manner but using d16 P1K dizzy, can this contribute to my missing issue?
is CKP, TDC coil etc sensor which are integrated in honda dizzy are different?
Old 11-22-2010, 11:07 AM   #9
I would say the D16 distributor is your problem.
The F22B1 and D16 mating grooves in the cam & distributor are 90 off. The mating groove of the D16 at top dead center is vertical ( | ) while the mating groove of the F22B @ TDC is horizontal ( - ). Changing to a SOHC F22B VTEC distributor should solve your misfire/missing idle issue.
Old 11-22-2010, 11:25 AM   #10
@ghostaccord!
im guessing the same, today our local junk yard was closed. so i'm gonna go to the market tomorrow and try a few dizzy
i'm tired of this issue, i need to get it sorted out. under too much stress and hating my innova
Old 11-22-2010, 01:08 PM   #11
do i need to get the P0A dizzy or is there any other dizzy which you think should work?
Old 11-22-2010, 01:13 PM   #12
I would suggest picking up the P0A...... I'm not aware of any other distributor that would be plug-n-play.
Old 05-22-2012, 11:21 PM   #13
I have the same problem with my car any advice?
mvlopez24 is offline   Reply With Quote
Backfire from Intake 94 lude f22b1 HondaTechMan121 Honda Prelude 15 06-12-2016 04:33 PM
bad crank position sensor??? i need expert help! redline870 Honda Accord (1990 - 2002) 46 04-01-2013 02:52 PM
b18c type r swap in 90 integra-ecu throwing out CEL code 26 WTF!!?? HELP!! mrafd Hybrid / Engine Swaps 3 11-01-2009 05:02 PM
Firing order for f22b1 wcoleman Honda Accord (1990 - 2002) 1 06-05-2009 02:10 PM
will no one f'in help me FIRING ORDER !! fastgreenmachine Honda Civic / Del Sol (1992 - 2000) 13 02-28-2003 11:28 AM
Tags
f22b, f22b1, f22b2, find, firing, honda, jdm, motor, order, plug, sequence, sohc, tdc, vtec, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
