problem shifting from park to drive - Honda-Tech
Old 11-17-2005, 06:30 AM   #1
drunkinmiami's Avatar
Default problem shifting from park to drive
im having some problem with my 99 accord when trying to shift from park to drive or reverse. after stepping on the brakes for about 5 or 6 times i get lucky to shift the **** to reverse. any one know what the problem is? brake sensor?
drunkinmiami is offline   Reply With Quote
Old 11-17-2005, 07:08 AM   #2
In a Junkyard near you.
Ross 2.0's Avatar
When this is happening get someone to look at your brake lights. If they don't work when you press the brake then you need to replace the brake light switch on the brake pedal.
Ross 2.0 is offline   Reply With Quote
Old 11-17-2005, 12:20 PM   #3
Default Re: (MooGoCow3)
thank you i will find out once i reach home
Old 11-17-2005, 12:43 PM   #4
P_Adams's Avatar
Default Re: problem shifting from park to drive (drunkinmiami)
It's what's called the shift interlock system. It keeps the shifter from moving until the brakes are applied.
There are two major components:
DPST Stoplight switch (Dual Function)
Interlock Solenoid @ shifter.
There are two ways the switch can fail:
!) Misadjusted (Stop Lamp trick check) from size 12.5 EEE gunboats rummaging around under the dash
2) Electrical Failure (doesn't close, passing voltage to solenoid)
The connector at the switch can come loose (refer 1 )
or the solenoid could be bad.
P
P_Adams is offline   Reply With Quote
Old 11-17-2005, 06:41 PM   #5
Default Re: (drunkinmiami)
u were correct about this when this happens the brake light does not work even though im applying the brakes!!!! as soon as the brake light works im able to shift it from park to reverse or drive.
so ur telling me to replace the brake light switch on the brake pedal right? is that easy to replace or do i have to take it to a transmission place? is it going to be expensive?
Old 11-17-2005, 06:44 PM   #6
BLKFLSH's Avatar
Should be pretty easy, look under the brake pedal. Maybe two screws and a plug.
BLKFLSH is offline   Reply With Quote
Old 11-17-2005, 06:51 PM   #7
P_Adams's Avatar
The Brake lamp switch is a simple and unexpensive piece to have replaced. It's mounted in the vicinity of your Brake Pedal. If you're small enough, it would be possible to do this yourself (in that you have to work under the Dashboard, upside-down on your back), and you had the correct tools.
Either that or have your Mechanic / Repair Guru do the job. Hopefully, his labor rate won't be way up there.
P
Old 11-19-2005, 01:52 PM   #8
today morning i decided to try my luck. as per the instructions i squeezed myself upside down to find the brakelight switch. It was easy to remove. I tried all the auto shops but they dont keep the brakelight switch in stock. if i order it it would take another 3 or 4 days, instead i decided to try to go to the honda dealer , the price of the part was twice the rates in the auto store, but anyway i bought it replaced the old part put the new one in. AND ITS WORKING GREAT!!!
THANKS TO ALL U GUYS WHO GAVE ME THE DETAILS OF THE PROBLEM
problem shifting from park to reverse 95 accord glen123 Honda Accord (1990 - 2002) 1 10-08-2016 06:48 PM
2002 Odyssey shifs to easily bruceb Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V 2 12-24-2010 03:15 PM
92 prelude help. (shifting) auto. si_kidd Honda Prelude 4 08-06-2009 08:06 PM
98 auto accord shifting problem XTYPES Honda Accord (1990 - 2002) 2 07-02-2009 05:24 PM
Shift interlock mechanism problem when in Park honda civic ex 2002 auto trans? ak11228 Honda Civic (2001 - 2005) 1 02-24-2009 03:16 PM
Tags
2004, accord, drags, drive, honda, park, problem, shift, shifting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
