92 HONDA ACCORD PROBLEMS!!
HI I GOT A 92 HONDA ACCORD, APPARENTLY IT IS LEAKING OIL. AS FAR AS I CAN SEE, THERE IS OIL BY THE TIMING BELT AND HEAD AND BY THE DISTRIBUTOR?...ALSO WHEN MY CAR IS IN DRIVE MODE MY BRAKE PEDALS SEEM TO SLOWLY FALL, I HAVE TO PUMP IT FEW TIMES FOR IT TO BRAKE NORMALLY.. CAN SOMEONE PLEASE HELP ME?! AND ALSO WHAT PSI SHOULD I BE RUNNING ON?
Re: 92 HONDA ACCORD PROBLEMS!!
Sounds like your master brake cylinder is either going bad or already there. You should fix that first as that can cause your brakes to fail while driving which could be fatal.
Racersky
01-27-2006 07:57 AM
