How much of a difference?
Old 10-12-2005, 06:02 PM
Redneck94Honda's Avatar
Default How much of a difference?
How much of a power difference would there be between a stock F22a6 Header and this header on a 94 F22B2 Accord
http://cgi.ebay.com/ebaymotors...QrdZ1
any input would be helpful
Old 10-12-2005, 06:58 PM
P_Adams's Avatar
Default Re: How much of a difference? (Redneck94Honda)
Any horsepower increases anticipated from a header installation would be minimal by itself. The real improvements are realized when you make improvements to the entire exhaust system. The reason?
You must visualize the entire exhaust system (from the cylinder head exhaust valve head to the muffler exhaust tip) as a single pipe of a finite size through which you're going to force (flow) as much exhaust as possible. The reality of it is the system will only flow as much as the most restrictive point will allow. IE: Improving exhaust flow thru the header will have no net effect if your mufflers' restrictive etc.
A well designed system could get you 10 to 15hp at the wheels (at specific rpm ranges)
Honda's appear to respond well to the 4/2/1 style header. There has been some speculation that the collector portion on some brands could stand to be enlarged.
If you're hot for a header, be ready for increased underhood noise and heat; and make provisions for them.
P
Racermech
09-28-2006 07:55 AM
em1_mark
12-28-2005 10:09 PM
X_Ice_X
02-01-2005 08:50 PM
972drcordex
07-19-2004 10:53 PM
jamesbrown18
06-17-2004 03:46 AM
Quick Reply: How much of a difference?
