M3 mirror installtion instrucation on a 94 accord
Old 09-22-2008, 11:50 AM
Jokergp's Avatar
Default M3 mirror installtion instrucation on a 94 accord
I need help on this the m3 mirrors are mounted on already what i need is help with the wiring dnt no what to wire with what conection its a power mirror!!! Can any one help
Old 09-24-2008, 07:12 AM
Jokergp's Avatar
Default Re: M3 mirror installtion instrucation on a 94 accord (Jokergp)
Does any1 know
Old 09-25-2008, 12:21 PM
BBallz24's Avatar
I did a writeup on these once, not sure where it is. It's not hard. I'll see if I can locate it.
Old 09-27-2008, 12:03 PM
Jokergp's Avatar
Default Re: M3 mirror installtion instrucation on a 94 accord (BBallz24)
yea or a simple copy of wiring diagram will do!!!
Old 03-06-2009, 09:59 AM
BBallz24's Avatar
I can't find it......but it wasn't hard. I took the stock wire harness and connected the M3 harness to it. You might have to play around (move the wires) to get them to function properly. IIRC the M3 harness had 3 wires, and the stock had 4. This just means one wires (M3) goes to 2 (stock). As far as the turn signal goes, I just tapped into the turn signal, ran about 6' of wire and connected it to the M3 mirror LEDs. I ran the wires through under the fender, into the cabin (same spot os fog light wires) and then through the door grommet into the door itself and connected to mirror.
xxstrataxx
07-31-2010 03:56 AM
gsr civic dx
11-30-2005 10:49 AM
adharl
10-30-2005 09:50 AM
badluckcivic
05-30-2004 09:57 PM
.jacob
11-05-2002 09:58 AM
Quick Reply: M3 mirror installtion instrucation on a 94 accord
