Please help.. H22a4 swap
My car is a 97 accord lx. I used a obd2 f22b1 harness. Almost all plug n play.. My motor is a h22a4 obd2. I have a handful of plugs I can't figure out what they go too.. Could anyone help me... I need to find plug for my iacv, egr valve, intake air temp. Can someone provide me with wire colors or diagram.. Can post pictures upon request. Please help.. Thank you
Re: Please help.. H22a4 swap
If you are using a 97 F22B1 engine harness the connectors should be pretty easy to spot.
IACV - 2 pin (next to the TPS connector)
- BLK w/ BLU stripe
- YEL w/ BLK stripe
EGR Valve - 3 pin
- YEL w/ BLU stripe
- GRN w/ BLU stripe
- WHT w/ BLK stripe
IAT sensor - 2 pin (should also be right along side the TPS and IACV connectors)
- RED w/ YEL stripe
- GRN w/ BLU stripe
- BLK w/ BLU stripe
- YEL w/ BLK stripe
EGR Valve - 3 pin
- YEL w/ BLU stripe
- GRN w/ BLU stripe
- WHT w/ BLK stripe
- RED w/ YEL stripe
- GRN w/ BLU stripe
I'm about to do a f20b jdm swap in a 97 accord here soon
i bought it with the engine harness and ecu...
what else would I be expecting. Can I use my f22 flywheel and starter? And what about the vacuum lines? How much difference in the jdm from what is the car?
97LXF20B
10-09-2007 09:49 AM
