Please help, 94 Accord turn signals!
Old 10-04-2014, 06:12 AM
AntCrace's Avatar
Default Please help, 94 Accord turn signals!
I know this is up here a lot, but I just bought a 94 Accord and all of my lights work, hazards blink as they should, head lights come on and high beams work, but I have no turn signals. I replaced the flasher, I checked every fuse marked turn signal and hazard under the dash and under the hood that I could find. When you use the turn signals no lights come on in the dash, and the flasher isn't clicking. I don't know what to do? Thanks!
Old 10-04-2014, 01:43 PM
forward's Avatar
Default Re: Please help, 94 Accord turn signals!
Check each bulb and bulb socket, and replace as necessary. I just replaced a backup light bulb that looked fine (filament was fully intact, contact/ground was clean), and when I installed a new bulb, it worked again.
Old 10-04-2014, 08:17 PM
EGxBoostFiend's Avatar
Try checking the multi-function switch. (The actual lever you move to turn the turn signals on)
Jose Gomez
11-09-2023 06:34 PM
jmora525
10-15-2013 08:01 AM
slew0302
12-21-2008 05:56 PM
BrownGSR
03-16-2004 09:19 AM
Quick Reply: Please help, 94 Accord turn signals!
