part that work with f20b
i have looked around and noticed that a lot of people are having trouble finding parts for the f20b. so i done a lil reshearch and found some info and you all can correct me if im wrong.
F20B shares...
Intake 34mm & exhuast 29mm Valves with
H23A1
F22
F23
Pistons 85mm
F22
Head Gasket
F22 Bore: 86mm Thickness: .026
Main Bearings width .784
Any H/F series
Rod Bearing width .762
H22A4
H22A
H23A
H23A1
F22
Main Journal Diameter 55mm
H22A4
H23a
F23
Rod Journal Diameter 1.771
F23
Wrist Pin Diameter .866
Any H/F series
Deck Height 8.643
All H/F series
BE Bore 1.890
F23
If you would like to add any info please feel free. this is info i gathered from other sites and just put it togather for others to have some kind of referance of the F20B to the H/F series motors.
F20B shares...
H23A1
F22
F23
Pistons 85mm
F22
Head Gasket
Any H/F series
H22A4
H22A
H23A
H23A1
F22
H22A4
H23a
F23
F23
Any H/F series
Deck Height 8.643
All H/F series
BE Bore 1.890
F23
Re: part that work with f20b
The F20B does not share the same piston as an F22. Different comp height. It has 30mm exhaust valves which is the same as an H22. B16 sized rod bearings and rod journals. No internal oil squirters or external oil cooler. Inside the block it does have a 17mm head bolt plugging the feed for an oil jet system, but it has no provisions with which to bolt an oil jet system in the block. Shares oil pans with an F23 and a unique oil strainer. Do not use an H22 oil strainer on this motor because it is too long and you'll starve the motor (because it will sit right against the bottom of the oil pan) Not to mention that it has a unique head gasket not shared with any of the other motors (if you had them both side to side and compared you'll see why).
Justin Jones
K Series
12-31-2010 04:22 PM
The_Head
11-22-2005 04:15 PM
