88 Accord Idle Hunts up and down when in park and car is warm. any ideas?
Old 09-16-2005, 09:14 AM
SlackerAccord's Avatar
Default 88 Accord Idle Hunts up and down when in park and car is warm. any ideas?
my 1988 accord lx-i has an idle problem. When the car is warm and in park the idle goes from 1250 to 1500 or even 1750 and back down constantly. i have already checked for vacuum leaks. there are none. if any body has any other ideas i could really use the input. thanks.
Old 09-16-2005, 11:25 AM
deserthonda's Avatar
Default Re: 88 Accord Idle Hunts up and down when in park and car is warm. any ideas? (SlackerAccord)
remove the top cover off the fast idle valve, 2 phillip screws ,get a screwdriver and turn in the big black valve in there ,, do not overtighten it ...
Old 09-22-2005, 12:07 PM
Default Re: 88 Accord Idle Hunts up and down when in park and car is warm. any ideas? (deserthonda)
I adjusted the idle speed control valve on the old one and the new one but all it did was drop the speed of the idle cuz it still hunts. does any one have any other ideas cuz im all out of them. I've tried every thing thatmybuddys and I know of but we still cant figure it out. any and all help would awesome and much appreciated. Thanks
Old 09-22-2005, 08:49 PM
ericw's Avatar
Check your coolant and make sure it is toped off and bleed since it runs through the bottom of the fast idle valve. If that doesn't help then you might want to read through some of the threads at 3GEEZ of other people that have had the same problem and you might find some other ideas of what to check out.
rockycat
02-19-2015 05:59 PM
genopian
07-23-2014 06:45 PM
sun_zinc
07-13-2008 01:19 PM
b18cvtec
07-16-2003 04:16 PM
mrpickyman
11-02-2002 05:22 PM
Quick Reply: 88 Accord Idle Hunts up and down when in park and car is warm. any ideas?
