P2U5 swap with H2A5??
Old 01-04-2015, 01:02 PM
charliecd5's Avatar
Default P2U5 swap with H2A5??
I have a 95 F22B1 with the P2U5..I also have a H2A5 that was from a 92' F22A1..would I beable too swap and use the H2A5 with my B1? And if so is there any kind of modifications id have too do?
Old 01-04-2015, 05:43 PM
chrisnick's Avatar
Default Re: P2U5 swap with H2A5??
Yes, probably need to drill and tap the two holes for the mount. But why? Older transmission, more than likely higher miles and no gearing advantage.
Old 01-05-2015, 03:49 PM
charliecd5's Avatar
its a transmission that I've had for quite a while and my P2U5 lost reverse.I hear it could be a simple linkage issue but im not 100% and when I last ran the H2A5 there was no problems..are you familiar with one that just looses reverse and nothing else..Ive driven it like this for some time with no interference with 1-5
Old 01-05-2015, 04:25 PM
chrisnick's Avatar
MAD_MIKE would have more insight on the transmission internals, but I believe 5th and Reverse are paired.
Old 01-06-2015, 06:27 PM
MM Gruppe B
MAD_MIKE's Avatar
I'm more of an automatic transmission geek, but a transmission geek none-the-less.
H/F-Series Transmission Codes & Ratios - Honda Prelude Forum
P2U5- 3.307 -- 1.809 -- 1.185 -- .933 -- .658 -- 3.00 -- 4.062
H2A5- 3.307 -- 1.809 -- 1.185 -- .870 -- .685 -- 3.00 -- 4.062 DX/LX
H2A5- 3.307 -- 1.809 -- 1.230 -- .903 -- .705 -- 3.00 -- 4.062 EX
Pretty close gear ratios.
90-97 Accord transmissions are pretty much the same externally. Just transfer any brackets over to the 'new' transmission.
Old 01-07-2015, 09:09 AM
charliecd5's Avatar
yes 5th and reverse are..its just odd one day no bang tick pow nothing. never grinded..its like theres something blocking it from going into gear? im no mechanic for sure. I think I know just enough too **** myself.but I wanna eventually know my accord all the way down too the bolts. I really appreciate all the insight and info from all you guys \m/
Old 01-08-2015, 09:35 PM
MM Gruppe B
MAD_MIKE's Avatar
If 5th and Reverse share the same shift linkage, it may be that a pin or bolt has backed out. Might be lucky and see a problem on the external shift mechanism.
93gsrhatchbrid
04-22-2006 10:01 AM
AutoTrenz702
02-02-2006 05:29 PM
IA95civicDX
08-14-2005 07:37 PM
quick gixxer
02-09-2005 05:14 PM
a2sportcompacts
11-19-2003 09:57 PM
Quick Reply: P2U5 swap with H2A5??
