P2A5 or P2U5? - Honda-Tech
P2A5 or P2U5?
Old 07-29-2009, 01:24 AM   #1
fastshift's Avatar
Default P2A5 or P2U5?
I know P2A5 is for 94-97 F22B2 and P2U5 is for F22B1
I also know the only difference in gearing ratio is that
the forth in P2A5 is 0.903, and in P2U5 is 0.933
will 0.03 difference make a big difference?
Also, will P2U5 simply bolt on F22B2 block?
I tried to search the difference between those two but I had no luck finding the info i needed.
fastshift is offline   Reply With Quote
Old 07-29-2009, 02:11 AM   #2
fastshift's Avatar
Default Re: P2A5 or P2U5?
sorry I know it bolts right on but i still need to know the difference even if it's only a tiny difference
thanks
Old 07-29-2009, 09:43 AM   #3
I'd go for the P2U5 just because it has greater gain..
OCAccord02 is offline   Reply With Quote
Old 07-29-2009, 06:04 PM   #4
nus_dogg's Avatar
Really? I did a part number comparison through Majestic Honda parts site and all the gearing has the same part number between an LX and a EX trans. Also, other Accord members told me that there's no difference at all either.
At first of my swap, I started out with my EX tranny then as I took it apart again for a clutch job, I had to buy another lower mile tranny since my first tranny came with the car brand new which now is around 400K. So I got an LX tranny for only 150.00 while other place wanted 300.00 for an EX trans. LOL To be honest, There's no difference between the two and I didn't notice any gear ratio difference.
nus_dogg is offline   Reply With Quote
P2U5 swap with H2A5?? charliecd5 Honda Accord (1990 - 2002) 6 01-08-2015 10:35 PM
HELPPP!!!!!! F22 with H22 Pistons 95accord3267 Honda Prelude 18 08-22-2014 02:10 PM
OBD 0,1 and 2 Honda ECUís $25 each, 3 for $60 or the entire lot $250 kiDchaos Northeast (Sales) 6 11-09-2013 01:54 PM
Helppp!! F22 With H22 pistons 95accord3267 Honda Accord (1990 - 2002) 7 02-28-2012 01:03 PM
real quick distributor question crx_si-r Honda Civic / Del Sol (1992 - 2000) 7 12-22-2007 06:10 PM
Tags
accord, code, gear, h22, h22a, honda, p2a5, p2u5, ratio, ratios, swap, tranny, trans, transmission, transmisson, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
