P1456 90 EVAP Emission Control System Leak Detected (Fuel Tank System)? - Honda-Tech
Old 09-10-2012, 08:44 AM   #1
Default P1456 90 EVAP Emission Control System Leak Detected (Fuel Tank System)?
I'm not a car guy, not at all. I do however have no problem researching things and changing my own oil. The check engine light on my 1996 Accord came on and I bought an OBDII tool, which gave me code: P1456.
Looking that up here it said: P1456 90 EVAP Emission Control System Leak Detected (Fuel Tank System)
What's next, what do I need to do? Is this something I need to bring it in for? What can I do to possibly visually verify this issue?
bighammer is offline   Reply With Quote
Old 02-28-2013, 06:49 PM   #2
Default Re: P1456 90 EVAP Emission Control System Leak Detected (Fuel Tank System)?
check gas cap that its on tight(replace with oem cap if needed)..Are you getting a gas smell?
FL023 is offline   Reply With Quote
Old 03-04-2013, 08:53 AM   #3
from my experiences evap codes happen in ALOT of vehicals.
had it happen in a 2000 silverado, 98 ram, 00 pontiac, and both my accords.
and so far luckly its always been the fuel cap. (knock on wood)
make sure you wipe the cap off as well as the filler neck for a good seal, tighten it on, then make it do a couple extra "clicks" i do 3 or 4 no problem.
other wise its something dealing with from what iv "heard" (not entirely sure) could be a hole in the filler neck, a charcoal canister (or equivalent)
best bet buy the 15$ new gas cap and have at it. once cap is on also remove the positive cable, let it sit off for 10min to reset the code drive it and if it comes on again check it.
Prophet1990 is offline   Reply With Quote
2001 Honda Accord Coupe LX Acceleration Problem Blighty Honda Accord (1990 - 2002) 2 02-09-2013 07:34 AM
ecu codes. sickofitall1113 Acura Integra 12 03-10-2007 07:13 AM
cel 1456 any info? satsilprelude Honda Prelude 4 12-05-2006 11:57 AM
check engine light...what can I do to fix code P1456? drkns Honda Civic / Del Sol (1992 - 2000) 5 07-21-2006 10:11 PM
How to reset the computer to clear OBD II code P1456 timus Tech / Misc 7 02-27-2004 04:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
