washer camber kit...
Old 04-23-2009, 12:22 PM
nickoz's Avatar
Default washer camber kit...
sooo i read this FAQ's on washer camber kit... how many washers would i need for my 96 accord.... its probley 3" of ground...( enough to fit front of a shoe under or so...) im thinking 6?
and what size are these bolts im getting? same ones but lil longer?
(honda dealer orr?) any info would be great... im not sure how to tell how many washers i need so it wont rub. I would like to try this out and post feedback!
Thanks
Old 04-23-2009, 12:35 PM
He knows where you live!
TheMuffinMan's Avatar
Default Re: washer camber kit...
Did you read the FAQ? I even updated it with pictures as to what you need to purchase. The washers are not going to solve a rubbing problem, they'll solve camber.
Old 04-23-2009, 12:57 PM
nickoz's Avatar
welll i seen ur pics very nice detailed etc... im not really rubbing its just my tires are lil bald on the inside of the tire... cuz camber im thinkin... im running 17" tires/rims... and probley 3" off the ground..
and for sizes... those sizes posted is wat i need... and as for how many washers?
Old 04-23-2009, 01:03 PM
I used 6 or 7 washers on each side and corrected about 1.5 to 2 degrees of camber. The bolts can probably take another one or two washers but not much more than that.
Old 04-24-2009, 12:50 PM
nickoz's Avatar
yah but what is camber exact? ppl are telling me i need camber kit cuz its so low to the ground.
how do i stop rubbing also?
Old 04-26-2009, 08:04 AM
nickoz's Avatar
Old 04-26-2009, 05:52 PM
propwdialogue's Avatar
Camber is the way your tires are "tilted" towards or away from the car...like so:
Lowering your car will have given you some negative camber. This can actually be beneficial to your handling, to a certain point, but will also give you uneven tire wear.
Old 04-26-2009, 06:14 PM
KidFrost's Avatar
this is false.
Old 04-26-2009, 06:18 PM
Originally Posted by KidFrost
this is false.
this is false
Old 04-26-2009, 07:08 PM
this is false.
reasoning? proof? just talking out of your bum?
Old 04-26-2009, 09:04 PM
nickoz's Avatar
thanks for picture! welll here is the thing... my tires all 4 or wearing on the inside... everywhere else is fine!....my alignment is shity... i bring it to get aligned and guy tells me he did the best he could cuz car is lowered... i just want no wear on tires, and my steering wheel back to normal instead of lil off to right...
Old 04-27-2009, 04:13 PM
Yeah, I'd go with the washer trick in the rear. An ingall's camber kit up front will also be helpful, and then getting it re-aligned (maybe by someone with some experience with lowered cars would be good).
Old 04-28-2009, 07:58 AM
nickoz's Avatar
this ingall's camber kit ....is it balljoints ? adjustable oneS? if so i thought upper control arm has to be replaced ...i thought you cant just pop in new upper balljoint in...itts all as one... let me know how you did this so i can order one... just wanna make sure before i order ... thanks
Old 04-28-2009, 08:24 AM
nickoz's Avatar
Ok well i called to get these bolts... and i told them i need 1 1.25x50mm long bolts... They asked what diameter... ???? anyone have this? please get back so i can get these... thanks
Old 04-28-2009, 08:37 AM
nickoz's Avatar
called honda dealer...10mm is diameter...can anyone say if this is right diameter of bolt? thanks.
Old 04-28-2009, 08:47 AM
Originally Posted by the thread that tells you how to do it in the second sentence
4 M10 x 1.25 x 50mm long bolts. Use atleast grade 8 if not higher. The grade 8s can be bought at advanced auto
Old 04-28-2009, 07:52 PM
nickoz's Avatar
I know i wrote that down n told them... they need diameter... i called dealer.. i guesss 10 mm .... so got them on order. get them thursday so when i get chance ill be doing it. probley SATurday. Ill post how it went!
Thanks everyone for input.
Old 04-28-2009, 08:32 PM
Just hit up an auto parts store. Probably cheaper anyways
Old 04-28-2009, 09:25 PM
dtapia's Avatar
i use the camber shims and stack 3 of the #3 shims and i have about 1 deg of camber and the car is about 2" lowered using a Gc kit.
Old 04-28-2009, 09:26 PM
dtapia's Avatar
whats up muffin man i see your still rocking the crown. lol
Old 04-28-2009, 09:27 PM
Yes sir yes sir!
Most likely selling my Accord is what's up at the moment. Getting myself a graduation present more or less but can't keep two goodies
Old 04-29-2009, 12:33 PM
Nobody is going to buy your car...you should part out your suspension to me :-D
540dude
Suspension & Brakes
04-23-2012 02:23 AM
Xathine
Suspension & Brakes
38
10-15-2008 09:51 PM
E36 Guy
16
04-07-2006 09:58 AM
Ep3-4-EVA
11-15-2003 05:10 PM
im_the_teacher
09-20-2003 11:25 PM
Quick Reply: washer camber kit...
