P0744 Error Code
P0744 Error Code
I have a 1997 Honda Accord, 4 door, and I am getting an error code.
Well I was getting the P0740 error code, had the transmission rebuilt. Supposibly, replaced all the electronics, torque converter, and then the normal, seals, gaskets, plates, etc. Then after a few days, the P0740 came back on. Took it back in. They kept it close to a week. Now, about 3 wks later, I get a P0744 - voltage signal from the torque converter clutch is intermittent. Any one have any knowledge on this code? Thanks....
Jimmy
Jimmy
make sure there are no loose wires going to your lock up control and the shift solenoid valves,,that would give you code p0740 ,take it back to those guys and have them fix for you
