Oil Pump Gasket - Honda-Tech
Oil Pump Gasket
Old 06-05-2011, 11:56 AM   #1
Icon2 Oil Pump Gasket
Got a 95 Honda Accord EX V6 2.7L and i've got an oil leak coming from between my oil filter housing and my oil pump. I've come to the conclusion it's the oil pump gasket (#31 below) and i was just wondering if anyone on here has ever replaced this gasket before and if so how hard is it to do? I'd like some pointers and suggestions if possible as there isn't very much room to work in that area at all and i'd like to have a plan before i go tackling this thing. Thanks for any input.
Nshouse0003 is offline   Reply With Quote
Old 06-06-2011, 06:09 PM   #2
Default Re: Oil Pump Gasket
Having the exact same leak..hopefully someone will chime in..
Jdm1117 is offline   Reply With Quote
Old 06-08-2011, 01:19 PM   #3
nus_dogg's Avatar
It doesn't look too bad, but maybe the clearance between the chasis and engine may be a tight spot to work with.
nus_dogg is offline   Reply With Quote
Old 06-09-2011, 12:29 PM   #4
#31 is likely an o-ring. This is the back of the oil pump from my F22a1. I was puzzled, and even posted a thread about the lack of gaskets Honda uses on oil components, especially where the surfaces mate. The entire perimeter of this oil pump does not have a gasket! You just use Hondabond (RTV). So, when you remove the oil filter bracket to replace the o-ring, I'd recommend cleaning the surfaces where they mate (acetone worked great for me) and applying a bead of Hondabond. Unfortunately, I already had the engine pulled when I did all of this, so I can't be much help in the "how hard will it be?" department. Good luck!
supracord is offline   Reply With Quote
99 vtech smoke issue gumby87 Honda Accord (1990 - 2002) 3 05-02-2014 03:25 AM
odd differential request Spawne32 Transmission & Drivetrain 1 01-06-2012 01:00 PM
96 Wagon SRS Module CDelgado220 Honda Accord (1990 - 2002) 2 05-05-2010 11:50 PM
Sohc oil pan baffle goofyej6 Honda Civic / Del Sol (1992 - 2000) 3 10-16-2005 10:39 PM
OEM JDM 94-97 DC Si-VTEC Lips in stock! 2 available, BRAND NEW HONDA MrHeeltoe Miscellaneous - Appearance - Lighting 14 07-25-2005 02:49 PM
Tags
1995, 1997, 2000, 27, 27l, 95, accord, civic, gasket, honda, leak, leaking, litre, oil, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
