Oil Life on 06 accord coupe
After changing my oil, Do i have to reset the oil life meter on the odometer? If so how do i do it? Or do i just leave it alone and it will reset itself.
Re: Oil Life on 06 accord coupe (Lg33kt)
You do have an owner's manual, right? Please read it. When you have a question about your car, look it up. Good luck with the new car.
while the car is turned off, press the reset buttong on your gauge cluster. hold it down, and turn the key to the one position, and continue to hold the reset button for at least ten seconds.....20 or 30 is fine as well.
as far as i know the owners manual does NOT cover this.
Re: (v4lu3s)
That's the procedure for resetting the maintenance required light on the 03 model. It is covered in the owner's manual. They print owner's manuals for a reason. To give you useful information on your car. It's a pretty thick book, and you can learn a lot from it. Happy Hondaing
Re: (BLKFLSH)
thats funny...I have read that little book with all that stuff about the car...Hmm. Nothing. But hey thanks for one real answer. Maybe you should read that book on how to not be an ******* :D
Re: (Lg33kt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lg33kt »</TD></TR><TR><TD CLASS="quote"> Maybe you should read that book on how to not be an ******* :D</TD></TR></TABLE>
LOL
Turn your ignition on, hit the select button until the oil life % is showing, Push and hold the trip reset button until the oil lfe indicator starts flashing, (about 15 seconds) let off the button then push and hold it until it resets. (about 5 seconds)
LOL
GoLowDrew
08-14-2014 10:37 AM
s2kc's
Honda Civic (2006 - 2015)
10-30-2011 07:57 PM
